2 Replies Latest reply on Nov 15, 2007 10:08 AM by Snazzo
    CFLock Challenge with CFObject in Application.cfc
    Snazzo Level 1
      I occasionally get a cflock error when running an application in the morning. I moved several cfobject lines into the application.cfc onApplicationStart method. Some of the methods in the objects use cflock to read a session variable.
      Here is the error:
      Cannot lock session scope. Cannot use cflock to lock the application or session shared scopes without these scopes being established through the use of the cfapplication tag. To use the session scope you need to enable session management. Application and/or Session variables must also be enabled in the ColdFusion Administrator. <br>The error occurred on line 5.
