1 Reply Latest reply on Nov 11, 2007 8:02 AM by robdillon
    flv in swf issue
      I embedded a flv in a swf which work fine on its own but when I import the swf into director I just get a white box
      can any one help,
        • 1. Re: flv in swf issue
          robdillon Most Valuable Participant
          You probably have a version mismatch. If you are using Director MX 2004 without the update, then your Flash swf will have to be saved for the Flash player 7. If you've installed the .1 update for MX 2004 then you can use an swf that's saved for player 8.
