1 Reply Latest reply on Mar 6, 2013 8:51 AM by Jim_Simon
    CS6 Project Manager is not trimming R3D media.
    Neonhigh
      Hello,
      I am experiencing another problem with CS6 and R3D media.
      I am trying to move a PPCS6 project to an external hard drive in order to send it out for DI work.
      From Project Manager I select "create new trimmed project" with 24 frames handels.
      Once all the files are processed the resulting new project is huge and none of the clips have been trimmed.
      I tried to create a test sequence, with only 2 minutes of editing to see if the problem could have been solved with a fresh new sequence.
      Unfortunatelly I get the same rusults.
      CS6 is giving me several headackes with r3d media. I have been having several Unkown Errors while rendering or exporting different projects.
      Now I realize that CS6 cannot properly archive or copy trimmed projects.
      This is one of Andrew Davis's links that explains the archival process. Unfortunatelly it won't work woth r3d media:
      http://library.creativecow.net/devis_andrew/Archiving-Projects/1
      Pease let me know If you ever ecountered a solution to this problem.
      If of any help, here is my setup:
      MacPro 12cores
      64GB ram
      RedRocket
      nVidia Quadro
      Media is stored in an Internal raid
      Project Manager is set to export the trimmed project on a regula G-Raid drive with sufficient space and speed
      Thanks!
      Message was edited by: Neonhigh - Tutorial link added
