24 Replies Latest reply on Mar 8, 2013 1:17 PM by ignacio197
    Photoshop CS5: OpenGL disables as soon as I open a document
    ignacio197
      Hi all,
      I am experiencing a problem I dont understand with Photoshop CS5 ever since I bought a
      new monitor two weeks ago.
      I had a 17 inch Dell monitor and Nvidia card with 500MB of RAM and everything was working
      fine.
      I bought a 27 inch Dell U2713HM two weeks ago. I noticed that the OpenGL option in Photoshop
      was disabled, and hence I could not rotate the canvas easily. I thought it could be the graphics
      card having only 500MB of RAM available, and since I was now running at 2560 x 1440 resolution,
      that more RAM was needed for operations such as rotate. So I went and bought an Nvidia
      GTX630 with 4GB of RAM. Still it did not fix the problem and there is nothing I can do to activate
      the OpenGL option.
      If I open Photoshop, I can see in the preferences that the card is recognized fine, and I can play
      with the amount of RAM I want to leave free. However, as soon as I open a document or I create
      a new one (even as low as 100px by 100px) the option is disabled and photoshop complains that the
      document is not OpenGL enabled. If I go back to the 17 inch monitor, this new graphics card
      works also fine. So I dont think it has anything to do with the graphics card.
      I have updated all the drivers for the graphics card, mother board and everything available.
      Any ideas of why this is happening ? Its a bit of a shame, that with this bigger nicer monitor I
      cant take full advantage of some of the features of Photoshop. It also makes the zoom and another
      things go a bit non-smooth.
      Ignacio
        • 1. Re: Photoshop CS5: OpenGL disables as soon as I open a document
          Curt Y Level 7
          Do you have another GPU as well? Like an Intel onboard unit?  If so disable it.
          It is set up to run 3 monitors so seems like one 27 in should be no problem.
          • 2. Re: Photoshop CS5: OpenGL disables as soon as I open a document
            ignacio197 Level 1
            Mmm, I dont know. Its worth a check. I will do it later.
            Thanks!
            • 3. Re: Photoshop CS5: OpenGL disables as soon as I open a document
              Curt Y Level 7
              What OS?  You can see all the info with Win OS by clicking on Help/system info.  In Mac think that is in About Photoshop.
              • 5. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                Curt Y Level 7
                How much RAM?  Do you have at least a 300 watt power supply.  THat is minimium recommended for new card.
                • 6. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                  ignacio197 Level 1
                  I have 4GB of RAM as well as in the graphics card, and the power supply has 350 watt (I will double check this later when at home).
                  • 7. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                    ignacio197 Level 1
                    I cant find any other GPU in the mother board and the power supply is 560 watt. I have been trying more things but nothing
                    seems to work. I am lost with this one.
                    • 8. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                      ignacio197 Level 1
                      Well, I just found out something more weird. I lowered the resolution of the monitor from 2560x1440 to 1920x1200,
                      and now when photoshop is open and I open a document, all the 3D controls are enabled and I can play with the settings,
                      but still when I try to rotate the canvas photoshop shows the 'only works with OpenGL enabled documents'.
                      • 9. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                        Level 7
                        Can you post the contents from Help -> System Info ?
                        • 10. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                          ignacio197 Level 1
                          Hi Chris,
                          Here it is.
                          I can see here that it says
                            Video Card Memory: 0 MB
                          Is this the problem ? I can see however in the 3D section of the Preferences
                          total available VRAM: 4066
                          Thanks!
                          Adobe Photoshop Version: 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch]) x32
                          Operating System: Windows XP 32-bit
                          Version: 5.1 Service Pack 3
                          System architecture: AMD CPU Family:15, Model:3, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3
                          Physical processor count: 2
                          Processor speed: 3000 MHz
                          Built-in memory: 3295 MB
                          Free memory: 1801 MB
                          Memory available to Photoshop: 1639 MB
                          Memory used by Photoshop: 70 %
                          Image tile size: 1028K
                          Image cache levels: 5
                          Display: 1
                          Display Bounds:=  top: 0, left: 0, bottom: 1440, right: 2560
                          Video Card Number: 1
                          Video Card: NVIDIA GeForce GT 630
                          Driver Version: 6.14.13.1407
                          Driver Date: 20130210032028.000000-000
                          Video Card Driver: nv4_disp.dll
                          Video Mode: 2560 x 1440 x 4294967296 colores
                          Video Card Caption: NVIDIA GeForce GT 630
                          Photoshop scratch has async I/O enabled
                          Scratch volume(s):
                            C:\, 158,9G, 103,4G free
                          Installed components:
                             A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                             ACE.dll   ACE 2010/10/04-23:36:11   64.441628   64.441628
                             adbeape.dll   Adobe APE 2010/02/23-12:40:58   61.421986   61.421986
                             AdobeLinguistic.dll   Adobe Linguisitc Library   5.0.0
                             AdobeOwl.dll   Adobe Owl 2010/06/03-13:43:23   3.0.93   61.433187
                             AdobeOwlCanvas.dll   Adobe Owl Canvas   3.0.68   61.2954
                             AdobePDFL.dll   PDFL 2010/12/13-23:37:10   64.341419   64.341419
                             AdobePIP.dll   Adobe Product Improvement Program   5.0.0.2021
                             AdobeXMP.dll   Adobe XMP Core   5.0   61.134777
                             AdobeXMPFiles.dll   Adobe XMP Files   5.0   61.134777
                             AdobeXMPScript.dll   Adobe XMP Script   5.0   61.134777
                             adobe_caps.dll   Adobe CAPS   3,0,116,0
                             adobe_OOBE_Launcher.dll   Adobe OOBE Launcher   1.0.0.64 (BuildVersion: 1.0; BuildDate: Mon Jan 26 2010 21:49:00)   1.000000
                             AFlame.dll   AFlame 2010/02/23-17:27:33   61.421976   61.421976
                             AFlamingo.dll   AFlamingo 2010/02/23-17:27:33   61.421978   61.421978
                             AGM.dll   AGM 2010/10/04-23:36:11   64.441628   64.441628
                             ahclient.dll    AdobeHelp Dynamic Link Library   1,5,0,30
                             aif_core.dll   AIF   2.0   53.422628
                             aif_ogl.dll   AIF   2.0   53.422628
                             amtlib.dll   AMTLib   3.0.0.64 (BuildVersion: 3.0; BuildDate:  Mon Jan 26 2010 21:49:00)   1.000000
                             amtlib.dll_original   AMTLib   3.0.0.64 (BuildVersion: 3.0; BuildDate:  Mon Jan 26 2010 21:49:00)   1.000000
                             amtservices.dll   AMTServices   3.0.0.64 (BuildVersion: 3.0; BuildDate:  Mon Jan 26 2010 21:49:00)   1.000000
                             ARE.dll   ARE 2010/10/04-23:36:11   64.441628   64.441628
                             asneu.dll    AsnEndUser Dynamic Link Library   1, 7, 0, 1
                             AXE8SharedExpat.dll   AXE8SharedExpat 2010/02/23-17:27:33   61.421978   61.421978
                             AXEDOMCore.dll   AXEDOMCore 2010/02/23-17:27:33   61.421978   61.421978
                             Bib.dll   BIB 2010/10/04-23:36:11   64.441628   64.441628
                             BIBUtils.dll   BIBUtils 2010/10/04-23:36:11   64.441628   64.441628
                             boost_threads.dll   DVA Product   5.0.0
                             cg.dll   NVIDIA Cg Runtime   2.0.0015
                             cgGL.dll   NVIDIA Cg Runtime   2.0.0015
                             CoolType.dll   CoolType 2010/10/04-23:36:11   64.441628   64.441628
                             data_flow.dll   AIF   2.0   53.422628
                             dvaadameve.dll   DVA Product   5.0.0
                             dvacore.dll   DVA Product   5.0.0
                             dvaui.dll   DVA Product   5.0.0
                             ExtendScript.dll   ExtendScript 2010/10/19-10:22:12   61.445301   61.445301
                             FileInfo.dll   Adobe XMP FileInfo   5.0   61.134777
                             icucnv36.dll   International Components for Unicode 2009/06/17-13:21:03    Build gtlib_main.9896
                             icudt36.dll   International Components for Unicode 2009/06/17-13:21:03    Build gtlib_main.9896
                             image_flow.dll   AIF   2.0   53.422628
                             image_runtime.dll   AIF   2.0   53.422628
                             JP2KLib.dll   JP2KLib 2010/12/13-23:37:10   64.181312   64.181312
                             libeay32.dll   The OpenSSL Toolkit   0.9.8g
                             libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                             libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
                             LogSession.dll   LogSession   2, 0, 1, 11
                             MPS.dll   MPS 2010/12/13-23:37:10   64.450375   64.450375
                             msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                             msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.4148
                             msvcp71.dll   Microsoft® Visual Studio .NET   7.10.3077.0
                             msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                             msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.4148
                             msvcr71.dll   Microsoft® Visual Studio .NET   7.10.3052.4
                             msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                             msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.4148
                             pdfsettings.dll   Adobe PDFSettings   1.04
                             Photoshop.dll   Adobe Photoshop CS5   CS5
                             Plugin.dll   Adobe Photoshop CS5   CS5
                             PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (32 bit)   2.0.0.746
                             PSArt.dll   Adobe Photoshop CS5   CS5
                             PSViews.dll   Adobe Photoshop CS5   CS5
                             SCCore.dll   ScCore 2010/10/19-10:22:12   61.445301   61.445301
                             shfolder.dll   Microsoft(R) Windows (R) 2000 Operating System   5.50.4027.300
                             ssleay32.dll   The OpenSSL Toolkit   0.9.8g
                             tbb.dll   Threading Building Blocks   2, 1, 2009, 0201
                             TfFontMgr.dll   FontMgr   9.3.0.113
                             TfKernel.dll   Kernel   9.3.0.113
                             TFKGEOM.dll   Kernel Geom   9.3.0.113
                             TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                             updaternotifications.dll   Adobe Updater Notifications Library   1.0.0.68 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   1.0.0.68
                             WRServices.dll   WRServices Thursday January 21 2010 12:13:3   Build 0.11423   0.11423
                             wu3d.dll   U3D Writer   9.3.0.113
                          Installed plug-ins:
                             3D Studio 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Accented Edges 12.0
                             ADM 3.11x01
                             Angled Strokes 12.0
                             Average 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Bas Relief 12.0
                             BMP 12.0.2
                             Camera Raw 6.7
                             Chalk & Charcoal 12.0
                             Charcoal 12.0
                             Chrome 12.0
                             Cineon 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Clouds 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Collada 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Color Halftone 12.0.2
                             Colored Pencil 12.0
                             CompuServe GIF 12.0.2
                             Conté Crayon 12.0
                             Craquelure 12.0
                             Crop and Straighten Photos 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Crop and Straighten Photos Filter 12.0.2
                             Crosshatch 12.0
                             Crystallize 12.0.2
                             Cutout 12.0
                             Dark Strokes 12.0
                             De-Interlace 12.0.2
                             Dicom 12.0
                             Difference Clouds 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Diffuse Glow 12.0
                             Displace 12.0.2
                             Dry Brush 12.0
                             Eazel Acquire 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Embed Watermark 4.0
                             Entropy 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Extrude 12.0.2
                             FastCore Routines 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Fibers 12.0.2
                             Film Grain 12.0
                             Filter Gallery 12.0
                             Fresco 12.0
                             Glass 12.0
                             Glowing Edges 12.0
                             Google Earth 4 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Grain 12.0
                             Graphic Pen 12.0
                             Halftone Pattern 12.0
                             HDRMergeUI 12.0
                             IFF Format 12.0.2
                             Ink Outlines 12.0
                             JPEG 2000 2.0
                             Kurtosis 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Lens Blur 12.0
                             Lens Correction 12.0.2
                             Lens Flare 12.0.2
                             Lighting Effects 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Liquify 12.0.1
                             Matlab Operation 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Maximum 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Mean 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Measurement Core 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Median 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Mezzotint 12.0.2
                             Minimum 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             MMXCore Routines 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Mosaic Tiles 12.0
                             Multiprocessor Support 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Neon Glow 12.0
                             Note Paper 12.0
                             NTSC Colors 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Ocean Ripple 12.0
                             OpenEXR 12.0.2
                             Paint Daubs 12.0
                             Palette Knife 12.0
                             Patchwork 12.0
                             Paths to Illustrator 12.0.2
                             PCX 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Photocopy 12.0
                             Photoshop 3D Engine 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Picture Package Filter 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Pinch 12.0.2
                             Pixar 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Plaster 12.0
                             Plastic Wrap 12.0
                             PNG 12.0.2
                             Pointillize 12.0.2
                             Polar Coordinates 12.0.2
                             Portable Bit Map 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Poster Edges 12.0
                             Radial Blur 12.0.2
                             Radiance 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Range 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Read Watermark 4.0
                             Reticulation 12.0
                             Ripple 12.0.2
                             Rough Pastels 12.0
                             Save for Web & Devices 12.0
                             ScriptingSupport 12.0.4
                             Send Video Preview to Device 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Shear 12.0.2
                             Skewness 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Smart Blur 12.0.2
                             Smudge Stick 12.0
                             Solarize 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Spatter 12.0
                             Spherize 12.0.2
                             Sponge 12.0
                             Sprayed Strokes 12.0
                             Stained Glass 12.0
                             Stamp 12.0
                             Standard Deviation 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Sumi-e 12.0
                             Summation 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Targa 12.0.2
                             Texturizer 12.0
                             Tiles 12.0.2
                             Torn Edges 12.0
                             Twirl 12.0.2
                             U3D 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Underpainting 12.0
                             Vanishing Point 12.0
                             Variance 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Variations 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Video Preview 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Water Paper 12.0
                             Watercolor 12.0
                             Wave 12.0.2
                             Wavefront|OBJ 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             WIA Support 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             Wind 12.0.2
                             Wireless Bitmap 12.0.4 (12.0.4x20110407 [20110407.r.1265 2011/04/07:02:00:00 cutoff; r branch])
                             ZigZag 12.0.2
                          Plug-ins that failed to load: NONE
                          Flash:
                             Coolorus
                             Mini Bridge
                             Kuler
                             Access CS Live
                             CS Review
                             CS News and Resources
                          Installed TWAIN devices: NONE
                          • 11. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                            Curt Y Level 7
                            3D will not work with XP op. sys.
                            • 12. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                              Level 7
                              Yes, that would be part of the problem.
                              • 13. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                ignacio197 Level 1
                                Thanks for your replies. I can certainly try windows 7.
                                Just to check, if I swap monitors again (back to the 17 inch one),
                                I can still see
                                however I can use the rotate option and everything seems
                                to work fine.
                                Anyhow, why does photoshop see 0MB for the graphics card.
                                Is this due to some incompatibility ?
                                Ignacio
                                Free memory: 1851 MB
                                Memory available to Photoshop: 1657 MB
                                Display: 1
                                Display Bounds:=  top: 0, left: 0, bottom: 1024, right: 1280
                                Video Mode: 1280 x 1024 x 4294967296 colores
                                Scratch volume(s):
                                • 14. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                  ignacio197 Level 1
                                  Just to add more info on the graphics card memory:
                                  Type: DDR3
                                  • 15. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                    Level 7
                                    0 MB for the video memory is probably a bug in the driver software.
                                    You need to contact NVidia and get their help to figure out how the driver is malfunctioning.
                                    • 16. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                      ignacio197 Level 1
                                      Ok, I will give that a go and see how it goes. I will post any progress here for completion.
                                      Thanks!
                                      • 17. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                        ignacio197 Level 1
                                        One more test. I have gone back to my old NVIDIA 8800GT with 500MB of memory and Photoshop does
                                        recognize the 500 MB this time. But the rotate functions do not work although I can see the OpenGL functions
                                        enabled in the preferences. So I am guessing that 500MB is not enough to have these functions enabled on a
                                        2560x1440 screen resolution, because in the 17 inch monitor I can rotate the canvas with no problem.
                                        I dont know. Im taking back the NVIDIA 630GTX for now
                                        This wekeend I will try windows 7.
                                        Built-in memory: 3327 MB
                                        Free memory: 1742 MB
                                        Memory available to Photoshop: 1627 MB
                                        Display: 1
                                        Video Card: NVIDIA GeForce 8800 GT
                                        Video Card Caption: NVIDIA GeForce 8800 GT
                                        Video Card Memory: 512 MB
                                        Scratch volume(s):
                                          C:\, 158,9G, 102,8G free
                                        • 18. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                          Level 7
                                          You're on XP, where very little GPU code works - and Photoshop isn't detecting the needed capabilities from the driver (otherwise it would list them in the system info log).
                                          • 19. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                            ignacio197 Level 1
                                            Ok, thanks for the reply. Windows 7 it is then. I will write down if this solves the problem when I have it up and running.
                                            • 20. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                              Curt Y Level 7
                                              Win7 is good, also it you can bump RAM to 8 gig it will help a lot.  Many are going for 16 now.
                                              • 21. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                                ignacio197 Level 1
                                                Yes, I will try. At least I would be able to see the full 4GB I have now rather than the 3 and a bit that XP sees
                                                • 22. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                                  ignacio197 Level 1
                                                  Just to have a complete thread in case this is of use to anyone.
                                                  I have installed Windows 7 64bit.
                                                  I have returned the NVIDIA 630GT and I am back with my original NVIDIA GeForce 8800 GT
                                                  and 500MB of RAM. I am using my 2560x1440 screen resolution on the 27 inch Dell U2713HM.
                                                  Everything works perfectly fine now. Much faster and smoother transitions. The rotate function
                                                  works perfect. I can see now in the System Info how the OpenGL options show up. I never
                                                  knew they were supposed to be there!
                                                  So thanks for the tips, they really helped! Off to drawing .......
                                                  Adobe Photoshop Version: 12.0 (12.0x20100407 [20100407.r.1103 2010/04/07:14:00:00 cutoff; r branch]) x64
                                                  Operating System: Windows 7 64-bit
                                                  Version: 6.1
                                                  Built-in memory: 4095 MB
                                                  Free memory: 2236 MB
                                                  Memory available to Photoshop: 3443 MB
                                                  Memory used by Photoshop: 60 %
                                                  Image tile size: 132K
                                                  Image cache levels: 4
                                                  OpenGL Drawing: Enabled.
                                                  OpenGL Drawing Mode: Normal
                                                  OpenGL Allow Normal Mode: True.
                                                  OpenGL Allow Advanced Mode: False.
                                                  OpenGL Crash File: Not Detected.
                                                  OpenGL Allow Old GPUs: Not Detected.
                                                  Video Card Vendor: NVIDIA Corporation
                                                  Video Card Renderer: GeForce 8800 GT/PCIe/SSE2
                                                  Display: 1
                                                  Driver Version: 9.18.13.1407
                                                  Driver Date: 20130209000000.000000-000
                                                  Video Card Driver: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
                                                  Video Mode: 2560 x 1440 x 4294967296 colors
                                                  Scratch volume(s):
                                                    Startup, 111,6G, 82,4G free
                                                  • 23. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                                    Level 7
                                                    Glad you got it all working.  And I suspect that you'll be happier overall with Win7 (once you get over the UI changes and turn off UAC).
                                                    But don't forget to install the Photoshop updates - you're back to 12.0.0.
                                                    • 24. Re: Photoshop CS5: OpenGL disables as soon as I open a document
                                                      ignacio197 Level 1
                                                      Thanks for the reminder.
                                                      Ah, I just did. Didnt know you could control those anoying confirmation messages Thanks !
