7 Replies Latest reply on Sep 19, 2018 3:11 AM by Kals
    How to update a ScriptUIGraphics object?
    DBarranca Level 4
      Hello,
      I've been able to use ScriptUIGraphics, but as far as I've seen there's no way to update / change any object, nor it seems possible to call the onDraw() handler but once if it contains either fillPath() or strokePath() - which usually does.
      For instance, the following test script pops up a panel with a red square in it. Fine. When you click the "Try" button, the onDraw() is fired again and should draw a smaller square, but stops with a very informative "cannot execute" error at some point within the onDraw():
      // ScriptUI graphics update issue
      // resource string
      var winRes = "dialog {  \
          text: 'ScriptUI Graphics test',  \
          margins: 15, \
          alignChildren: 'row', \
          canvas: Panel {  \
              preferredSize: [200, 200], \
              properties: {borderStyle: 'black'} , \
          buttonsGroup: Group{ \
              cancelButton: Button { text: 'Cancel', properties:{name:'cancel'} }, \
              tryButton: Button { text: 'Try', properties:{name:'try'},size: [40,24], alignment:['right', 'center'] }, \
      // Window
      var win = new Window(winRes);
      // define the graphic property
      canvasGraphics = win.canvas.graphics
      // do the drawing
      win.canvas.onDraw = function() {
                // creates a red filled square
                canvasGraphics.newPath()
                canvasGraphics.rectPath(10, 10, 200, 200)
                canvasGraphics.fillPath(canvasGraphics.newBrush(canvasGraphics.BrushType.SOLID_COLOR, [1,0,0,1], 1)) // HERE
      win.buttonsGroup.tryButton.onClick = function() {
                win.canvas.onDraw.call()
      win.show()
      When you run it, it works as expected; if you click the Try button, an error is fired when the script gets to the line ("HERE" in the code), that is: when it comes to fill the path.
      Strangely enough! Because it doesn't seem to be a problem with the onDraw second call (apparently the second square path is constructed, but can't be filled).
      Am I doing something wrong here? Should I first delete the original square (how?!), or somehow initialize it again? Are ScriptUIGraphics immutable somehow?
      --- Update ---
      Further experiments led me to understand that onDraw() (so the whole drawing) seem to be called just once - when the Window is shown. I've tried to remove and rebuild the canvas Panel altogether, but its own new onDraw() is never called - nor an explicit call works. Apparently you can't invoke win.show() again, nor hide and show it. Ouch!
      Thanks in advance for any suggestion
      Davide
        • 1. Re: How to update a ScriptUIGraphics object?
          DBarranca Level 4
          It seems the trick is to switch from a Panel to a Custom component, which allows you something like:
          // do the drawing
          win.canvas.onDraw = redraw
          function redraw() {
                    canvasGraphics.fillPath(canvasGraphics.newBrush(canvasGraphics.BrushType.SOLID_COLOR, color(), 1)) // HERE
                win.canvas.notify("onDraw")
          It now works, but the component respond to all kind of events (mouseover, mouseclick), and I haven't been able so far to use successfully .preventDefault()
          • 2. Re: How to update a ScriptUIGraphics object?
            pixxxel schubser MVP & Adobe Community Professional
            Sorry, I do not understand what do you really want (because of my bad english)
            Try to change the bg color of the panel in the dialog box by clicking on button? Something like this?
            // resource string
                margins: 15, \
                canvas: Panel {  \
            // Window
            win.canvas.graphics.backgroundColor = win.canvas.graphics.newBrush (win.canvas.graphics.BrushType.SOLID_COLOR, [1,0,0],1);
            win.buttonsGroup.tryButton.onClick = function() { // change the graphic background property by click on Button [try]
            win.canvas.graphics.backgroundColor = win.canvas.graphics.newBrush (win.canvas.graphics.BrushType.SOLID_COLOR, [0,0,1],1);
            win.show()
            • 3. Re: How to update a ScriptUIGraphics object?
              DBarranca Level 4
              Hi pixxxel schubser,
              I'm afraid this is not what I meant, possibly I haven't chosen the best example: you can easily change properties, but the problem is that when you draw graphics (ScriptUIPath objects) inside a component (in my case a ScriptUI Panel), you're not allowed to stroke or fill them but once, when the Window is drawn - that is, the .onDraw() function is triggered by the win.show().
              Unless - I've discovered - you use a Custom component:
              canvas: Panel { ...
              // become:
              canvas: Custom { ...
              this, plus the handler I've written in my second post, actually solves the problem.
              Davide
              • 4. Re: How to update a ScriptUIGraphics object?
                Kukurykus Adobe Community Professional
                Could you post final code, as when I replace wrong part in your original one to that you marked as correct it doesn't work.
                • 5. Re: How to update a ScriptUIGraphics object?
                  Kals Level 1
                  'myObject.notify("onDraw")' is the real take-home lesson here. It evens works on icon buttons.
                  The docs say that the notify() method of a button accepts only 'one of: onClick, onChange, onChanging'. It says nothing about onDraw, but it works, and is simpler than other solutions I've seen discussed. Absolute gold!
                  • 6. Re: How to update a ScriptUIGraphics object?
                    Read about it in JAVASCRIPT TOOLS GUIDE you access from one before last item in 'Help' menu of ExtendScript ToolKit.
                    • 7. Re: How to update a ScriptUIGraphics object?
                      Kals Level 1
                      Ah yes, so there it is… an obscure (but very helpful) mention on page 164. :-)
