7 Replies Latest reply on Mar 18, 2013 7:20 AM by Cooroo
    AppleScript to check all pages within one Indesign (CS6) document have same size.
    hasi8
      I have bunch of InDesign (CS6) documents containing different page sizes (some are designed for a particular device and some are designed for multiple devices using alternate layouts). I need to assure all page sizes are same before I run a particular script.
      So I need a Applescript which can request a folder location of closed files and then open and run through the InDesigns in that folder (ignoring any other files) and then open a text file report saying all page sizes are same or not. (Sorry! for my English)
      Any help is much appreciated!
        • 1. Re: AppleScript to check all pages within one Indesign (CS6) document have same size.
          -hans- Level 4
          var selFolder = Folder.selectDialog();
          var inddFiles = selFolder.getFiles('*.indd');
          l = inddFiles.length;
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
          while(l--)
          currDoc = app.open(inddFiles[l], false);
          allPagesBounds = currDoc.pages.everyItem().bounds;
          currDocPagesWidthHeight = new Array();
          for(var b = 0; b < allPagesBounds.length; b++)
              h = allPagesBounds[b][2];
              w = allPagesBounds[b][3] - allPagesBounds[b][1];
              resString = '' + currDoc.pages[b].name + ': ' + w + ' x ' + h + '\n';
              currDocPagesWidthHeight.push(resString)
          toFile(currDoc.name.replace(/indd/,''), currDocPagesWidthHeight.join(''));
          currDoc.close(SaveOptions.NO);
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
          function toFile(targetName, pwh)
              targetFile = File(selFolder + '/' + targetName + 'txt')
              targetFile.open('w');
              targetFile.write(pwh);
              targetFile.close()
          quick'n dirty this should list all pagesizes of indd-docs of a chosen folder in the chosen folder with matching inddDocName.
          Docs will open faceless ... Javascript.
          Hope it'll be of some help
          Hans-Gerd Claßen
          • 2. Re: AppleScript to check all pages within one Indesign (CS6) document have same size.
            -hans- Level 4
            good morning,
            changed it a bit. this'll only write a reportfile if there are pages with different pagesizes.
            #target Indesign
            while(l--)
                var samePageSizesOrNot = checkUnique(currDocPagesWidthHeight);
                switch(samePageSizesOrNot)
                    case false :
            break;
            default : currDoc.close(SaveOptions.NO);
            break;
                targetFile.close()
            function checkUnique(someArray) {
                     var obj = {}  ;
                var tmpArray = []  ;
                     for (var i = 0; i < someArray.length; i++) {
                             var currItem = someArray[i];
                    if (! obj[currItem]) {
                        obj[currItem] = true ;
                                                 tmpArray.push(currItem);
                if (tmpArray.length === 1)
                    return true;
                    }else{
                        return false;}
            • 3. Re: AppleScript to check all pages within one Indesign (CS6) document have same size.
              hasi8 Level 1
              Thank you soooo much Hans!
              This is really great! Could it be possible to run on a bunch of folders and subfolders and in the end create a single txt file report?
              Hasi
              • 4. Re: AppleScript to check all pages within one Indesign (CS6) document have same size.
                -hans- Level 4
                sure,
                still no error-handling included, so use on own risk ;-) ...
                #target Indesign
                if(!selFolder) {exit();};
                var allFiles = selFolder.getFiles('*.*');
                var currDate = getDate();
                 var currLogFile = File(selFolder.toString() + '/' + currDate + 'pagesSizeLogFile.txt');
                 doStuff(allFiles);
                 currLogFile.execute();
                 function doStuff(filesFoldersArray){
                var l = filesFoldersArray.length;
                while(l--)
                  var   currItem = filesFoldersArray[l];
                if(currItem instanceof(Folder)){
                    nextItems = currItem.getFiles('*.*');
                    doStuff(nextItems);
                    else if (    currItem.displayName.indexOf('indd') != -1){
                    currDoc = app.open(currItem, false);
                currDocPagesWidthHeight = [currDoc.fullName.toString() + ':\n'];
                for(var b = 0; b < allPagesBounds.length; b++) {
                        case false :
                toFile(currDocPagesWidthHeight.join(''));
                break;
                default : currDoc.close(SaveOptions.NO); break; }
                function toFile(pwh)
                        currLogFile.open('a');
                    currLogFile.write(pwh);
                    currLogFile.close()
                           var tmpArray = []  ;
                    var tmpString = '';
                         for (var i = 1; i < someArray.length; i++) {
                             if (tmpString.indexOf(currItem.slice(2,-1)) === -1){
                                tmpString = tmpString + ' ' + currItem;
                        return true;
                        }else{
                            return false;}
                        function getDate(){
                    var d = new Date();
                var day = d.getDate();
                if(day < 10){day = '0' + day;};
                var month = d.getMonth() +1;
                if(month < 10){month = '0' + month;};
                var year = '' + d.getFullYear();
                var hours = d.getHours();
                var minutes = d.getMinutes();
                var seconds = d.getSeconds();
                 var dateString = month + day  + year.substring(2) + '_'  + hours + minutes + seconds + '_';
                 return dateString;
                • 5. Re: AppleScript to check all pages within one Indesign (CS6) document have same size.
                  Cooroo Level 1
                  Puzzled - surely this is Java not Applescript as requested??
                  • 6. Re: AppleScript to check all pages within one Indesign (CS6) document have same size.
                    -hans- Level 4
                    It's a javascript (Extendscript) and will run on both mac and pc
                    • 7. Re: AppleScript to check all pages within one Indesign (CS6) document have same size.
                      Cooroo Level 1
                      Thought so. Just OP asked for AS and seemed happy with JS! I think I need to learn JS... I am too stuck in my ways!
