2 Replies Latest reply on Mar 7, 2013 7:34 AM by Henrik Engedal Nissen
    Leading is not working!
      Hi, I have set all my paragraph styles to have a leading of 15. But even so, at the end of the document, the text on the left and right side are not at the same line height. They don't fit. I have seen if I did some mistake some where but I don't see that. Can anybody help me on this? I use Indesign CS5.
        • 1. Re: Leading is not working!
          Please post a screen shot. You can embed it in a post using the camera icon onthe web page, like this:
          Most likely causes are you have space before/after applied to some paragraph or you are using the Justified option for vertical alignment in the text frame options and have a different number of lines in each frame. Other possibilities include a paragraph break with the wrong leading, a single character with a different leading applied that pushes one line down, or an Align to Grid for first line, and the grid does not match the leading.
          • 2. Re: Leading is not working!
            Henrik Engedal Nissen Level 1
            I found the problem: I should also mention that I have put 2,646 mm before and after each quote. 5,592 should be the same size as 15 pt. But when a quote started on one page and finished on the next, the lines would not fit anymore.
