1 Reply Latest reply on Mar 8, 2013 12:38 PM by PoopPatrol
    Dreamweaver will not launch
    PoopPatrol
      Dreamweaver CS5.5 would not launch this morning.  My PC is running Windows 8, 64 bit.  Spoke to customer support and they had me uninstall CS5.5, and then installed CS6 through Adobe Application Manager.  I also installed the update for CS6 that was immediately available after installation of the new version.  Still will not launch.  I read forums and cleared the configuration files.  Still no launch.  On one attempt, I got the following event description:
      Problem Event Name:APPCRASH
        Application Name:Dreamweaver.exe
        Application Version:12.2.0.6006
        Application Timestamp:51111417
        Fault Module Name:mfc100u.dll
        Fault Module Version:10.0.40219.325
        Fault Module Timestamp:4df2e0e6
        Exception Code:c0000005
        Exception Offset:00251743
        OS Version:6.2.9200.2.0.0.256.48
        Locale ID:1033
        Additional Information 1:f795
        Additional Information 2:f795780d7fdfaf7f44020ca1c4402e11
        Additional Information 3:8124
        Additional Information 4:8124e6be7e1ed973f7c095ed2520b8af
      Any ideas?
      Read our privacy statement online:
        http://go.microsoft.com/fwlink/?linkid=190175
      If the online privacy statement is not available, please read our privacy statement offline:
        C:\WINDOWS\system32\en-US\erofflps.txt
        • 1. Re: Dreamweaver will not launch
          PoopPatrol Level 1
          If anyone else is having a problem with programs failing to launch in Windows 8, I finally tracked down a fix for the problem.  Evidentially, the file mfc100U.dll, noted as the Fault Module Name above, gets corrupted.  Simple fix.  Uninstall Microsoft C++ Restributable 2010, and reinstall same directly from the Microsoft site.  After two days of messing around, it fixed not only the freezing Dreamweaver launch, but Nikon's View NX2.  Good luck
