1 Reply Latest reply on Aug 29, 2006 3:51 PM by RoboWizard
    Split Tables
    maniac9999
      It seems like the table manipulation commands in RH X5 RoboHTML leave a lot to be desired, but hey, they're better than the ol' Forehelp. Can I split tables or only Split Cells? If so, how?
      Jim
        • 1. Re: Split Tables
          RoboWizard Level 4
          Hi Jim
          Give this a try:
          To manually split a table into two different tables:
          1. Select the row just above where the split should occur.
          2. Click the TrueCode tab
          The code for the complete row should be selected.
          3. Just after the </tr> code, enter </table>
          4. Look at the code preceding the selected text. There, you should find a tag beginning with <table and ending with some <col tags. Copy this and paste it on the empty row following where you added the </table> You might also want to add a line that looks like this:
          <p> </p>
          5. Save the page and switch back to WYSIWYG.
          Hopefully this helps... Rick
