0 Replies Latest reply on Mar 9, 2013 9:37 AM by Tap Root
    Canon Legria HF G25
    Tap Root
      I have recently purchased this camcorder. I have a small studio with Green Screen .
      First, there is no "firewire connection" on the camcorder ( why? I ask myself) which has caused me to import via a usb connection.
      When starting Premier Pro CS 6 I am asked to select a sequence. Which sequence is compatible with this camcorder?
      I chose a sequence and then imported the clip.  I was unable to use the keyframe function to remove the green chromatic background. Also, during play back there is a problem with audio synchronisation.
      Last, I want to import a screen capture clip produced in Techsmith Camstudio. What output format should I use to bring it into Abobe Premier Pro?
      I want to produce a 3 min clip for my website. If someone could please educate me as to which format I should use to bring my new camcorder, my green screen, adobe premier pro and camstudio to work together effortlessly.
      Man thanks for your time.
