1 Reply Latest reply on Mar 11, 2013 12:08 PM by Geoffroy Schneck
    selection problem
    KevinLiujw
      when I use xtype "selection",type "select" options use *json.jsp, but edit content cannot be displayed select content at the first time.
      second time edit content. can display this select content.
      please ask what reason ?
        • 1. Re: selection problem
          Geoffroy Schneck
          Can you be a little more specific / clearer on  how you try to achieve this ?
          One correct way to display the result of a json request in a Select List (here I want to display the running instances) :
          - On the widget node of xtype selection : set the 'optionsProvider' property to a function name (CQ.myapp.utils.getWFInstances)
          - Define this function like this :
          getWFInstances: function() {
                      var sampleData = [], results = CQ.Util.eval(CQ.HTTP.get('/libs/cq/workflow/content/console/instances.json')).workflows;
                      for (var i = 0, len = results.length; i < len; i++) {
                          var result = results[i];
                          sampleData.push({ value: result.model, text: result.model });
                      return sampleData;
          Resource hit by the request is /libs/cq/workflow/components/console/instances/json.jsp .
          It runs fine for me. Does this help for your use case ?
