8 Replies Latest reply on May 24, 2013 7:43 AM by NitroHazeDev
    asset metatadata information in a java process step
    sachin1107
      We need to write a java process in a process step of a workflow. We need to do certain actions based on the asset being referred in the workflow.
      I am not able to fetch the metadata of the asset(example image). Please share the code for fetching the
      metadata for an asset.
      Sachin
        • 1. Re: asset metatadata information in a java process step
          Geoffroy Schneck Level 2
          I assume you already managed to retrieve the Asset object out of the payload then ?
          See the API Javadoc of the Asset class here : http://dev.day.com/docs/en/cq/5-5/javadoc/com/day/cq/dam/api/Asset.html
          You can see you have 3 methods to get the Metadata information.
          So for example :
          Asset asset = resource.adaptTo(Asset.class);
          String assetTitle = asset.getMetadataValue("dc:title");
          • 2. Re: asset metatadata information in a java process step
            sachin1107 Level 1
            I am not sure how to get the resource object. I am trying to do it in a workflow process and defining resource as
            ResourceResolver resource;
            I believe this is not working as resource is not having any value. How can I get value of resource in a java workflow process.
            Thanks in advance.
            ~Sachin
            • 3. Re: asset metatadata information in a java process step
              If you implement the WorkflowProcess class, you should have access to the WorkflowItem and the session. Have a look at (1) .
              One way is to use a JCR resource resolver factory to access the Resource and convert it to an Asset. In your class definition :
              @Reference(policy = ReferencePolicy.STATIC)
              private JcrResourceResolverFactory jcrResolverFactory;
              then in your method :
              ResourceResolver rr = jcrResolverFactory.getResourceResolver(session)
              String path = item.getWorkflowData().getPayload().toString();
              Resource resource = rr.getResource(path);
              (1) http://dev.day.com/docs/en/cq/current/workflows/wf-extending.html#Defining a Process Step with a Java Class
              • 4. Re: asset metatadata information in a java process step
                sachin1107 Level 1
                This is the code I am using
                public class TestCode  implements WorkflowProcess
                1. private static final Logger log =     LoggerFactory.getLogger(TestCreateAssetWorkflow.class);
                  2. @Reference(policy = ReferencePolicy.STATIC)
                  3.   private JcrResourceResolverFactory jcrResolverFactory;
                4.    public void execute(WorkItem item, WorkflowSession arg1, MetaDataMap arg2)
                                              throws WorkflowException {
                                    // TODO Auto-generated method stub
                5.     try{
                6.       ResourceResolver rr = jcrResolverFactory.getResourceResolver(arg1.getSession());
                7.                 String path = item.getWorkflowData().getPayload().toString();
                8.       Resource resource = rr.getResource(path);
                9.                 Asset asset = resource.adaptTo(Asset.class);
                10.       String assetTitle = asset.getMetadataValue("dc:title");
                I am getting  java.lang.NullPointerException error on line 6 where I am trying to get ResourceResolver object. It seems the jcrResolverFactory is not getting intialized.
                The error stack trace prints:
                12.03.2013 15:20:24.488 *INFO* [JobHandler: /etc/workflow/instances/2013-03-12/model_1143994746278437:/content/dam/Test/workingOnComm unication/test5/photos/11331.tif] com.test.dampoc.TestCreateAssetWorkflow Stack Trace::java.lang.NullPointerException
                Please suggest how to proceed.
                Sachin
                • 5. Re: asset metatadata information in a java process step
                  Sham HC Level 7
                  Hi Sachin,
                      Which version of CQ. IIRC JcrResourceResolverFactory is depricated for 5.4 onwards. Instead use ResourceResolverFactory.
                  Sham
                  • 6. Re: asset metatadata information in a java process step
                    sachin1107 Level 1
                    Hi Sham,
                    I have tried using ResourceResolverFactory also, but it has not resolved the issue.
                    When ever I am trying to take the ResourceResolver object from ResourceResolverFactory, I am getting NullPointerException.
                    Below is the code I am using, Please suggest if I am making any mistake.
                    @Component(metatype = true, immediate = true)
                    @Service
                    @Properties({
                    @Property(name = Constants.SERVICE_DESCRIPTION, value = "ForTestingProcesses"),
                    @Property(name = Constants.SERVICE_VENDOR, value = "abc"),
                    @Property(name = "process.label", value = "TestProcess")})
                               private ResourceResolverFactory ResolverFactory;
                              ResourceResolver resourceResolver = null;
                              try{
                                        String path=item.getWorkflowData().getPayload().toString();
                                        log.info("TestCode Path::"+path);
                                        resourceResolver = ResolverFactory.getAdministrativeResourceResolver(arg2);
                                        log.info("Path2::"+path);
                                        Resource res=resourceResolver.getResource(path);
                                        log.info("Path3::"+path);
                                        Asset damAsset = DamUtil.resolveToAsset(res);
                                        log.info("damasset::"+damAsset);
                      }catch(Exception e){
                                                  log.info("Stack Trace::"+e);
                    if I include the line  @Reference(policy = ReferencePolicy.STATIC), It is giving error that the process is not found. If I am excluding the mentioned line, I am getting NullPointer exception.
                    Please suggest.
                    Sachin
                    • 7. Re: asset metatadata information in a java process step
                      KaushikNitin
                      Instead of exetending WorkflowProcess try AbstractAssetWorkflowProcess .
                      and in execute method try the folllowing code
                      getAssetFromPayload(workItem, workflowSession.getSession());
                      it will return you the current asset in payload .
                      There are various methods in AbstractAssetWorkflowProcess which you can use for asset processing.
                      Thanks . Hope It Will work for you.
                      • 8. Re: asset metatadata information in a java process step
                        NitroHazeDev Level 1
                        Hey Sachin,
                        Were you able to extract the metadata of an asset eg: image uploaded? I am stuck, need some advice on this.
                        Regards,
                        NZ
