1. Re: Detailed Contact Form-Adding fields-Using on own hosting
Vinayak_Gupta Mar 11, 2013 1:04 AM (in response to Ted flashscan8.us)The sites need to be hosted with Business Catalyst in order for the forms widget to work out of the box.
Users have also reported success adding contact forms to their site hosted elsewhere using Adobe FormsCentral, Jotform, or Wufoo and inserting them via Object > Insert HTML.
Read more about Muse's Contact form widgets here - http://www.adobekb.com/adding_contact_forms.html
"If you want to create and style forms with Muse and then upload your site to a different web hosting service, the forms will display as you designed them, but they will not function. If you have experience working with code, you can use Muse to export your site and then open the files in an HTML editor. Update the source code of the form to make it compatible with the form processing technology used by your hosting provider before you upload the files to their server."
Vinayak
