This question was posted in response to the following article: http://help.adobe.com/en_US/ColdFusion/10.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-7b61.html
What is the definition of a control character?
I would like to see an example that uses a loop that goes through the whole ASCII character set and outputs if the result of Trim(X) is different from X.
Ans: http://en.wikipedia.org/wiki/Control_character
AND I tested
<cffile action="read" file="#expandpath('test.txt')#" variable="test" >
<cfoutput>#len(test)#</cfoutput> // gives length:14
<cfoutput>#len(trim(test))#</cfoutput> // gives length:12
my input was : (ashishtondon and 2 times enter, 1 2 3 represents line number of my editor)
1 ashishtondon
2
3
<cfoutput>
<cfset get_array = ArrayNew(1)/>
<cfloop index="i" from="0" to="127">
<cfset with_out_trim = Chr(i) />
<cfset with_trim = trim(Chr(i)) />
#with_out_trim# // showing character value
<cfif compareNoCase(with_out_trim,with_trim) neq 0>
<cfset arrayAppend(get_array,i)/> //if with_out_trim is not equal to with_trim append index to the array
</cfif>
</cfloop>
</cfoutput>
<cfdump var="#get_array#"> // I dumped array i found from 1 to 32 all ASCII chars x are not equal with trim(x)
