3 Replies Latest reply on Dec 2, 2007 7:18 PM by Newsgroup_User
    rtmpchannel is undefined
    avenick8879
      Any help would be appreciated. I have been using Flex 2 and recently tried upgrading to Flex 3 beta 2. In my app i use a consumer and producer to connect to a external java jms topic. When I compile now in Flex 3 i get the error "Call to a possibly undefined method RTMPChannel". After searching doesn't seem to be under mx.messaging.channels anymore. Is there a new way to connect that is similar to RTMP? Or is this a bug?
        • 1. Re: rtmpchannel is undefined
          Level 7
          RTMPChannel is now in LCDS's fds.swc.
          If you don't need to connect to RTMP you can comment out the RTMPChannel
          from your services-config.xml, otherwise you'll need to add fds.swc to your
          Flex project's library path (and don't forget the locale/en_US/fds_rb.swc
          for localization strings too).
          Note that if you're building Flex Library projects (i.e. making swcs of your
          own), there's a known issue with Flex 3 Beta 2 that means you can't include
          Flex2 compiled swcs like fds.swc in the library path. This has been fixed
          since and you should be able to try out a nightly build of the Flex 3 SDK:
          http://labs.adobe.com/technologies/flex/sdk/flex3sdk.html
          Hello avenick8879,
          • 2. Re: rtmpchannel is undefined
            avenick8879 Level 1
            Thanks Peter, I had a fds.swc out on my server where the fds was living so i copied that over to the machine where my flex project is and linked it to the library path and I still got the error. I figured this was because it was from an older version of FDS and not LCDS, so I downloaded LCDS and ran the exe but I can't find a copy of fds.swc inside that? Where do i get fds.swc and will this work with the older version of FDS out on the server because I really don't want to mess with that configuration.
            • 3. Re: rtmpchannel is undefined
              Level 7
              LCDS is usually deployed as a J2EE WAR file, which is actually a compressed
              archive just like a .zip file. If you expand this you'll find /WEB-INF/flex/libs/fds.swc
              and /WEB-INF/flex/locale/en_US/fds_rb.swc.
