6 Replies Latest reply on Mar 12, 2013 3:36 AM by Test Screen Name
    Javascript help
    AffordableParalegal
      What am I forgetting?  Will these calculations actually work? Link to form - https://workspaces.acrobat.com/?d=CmBCPDROCLXR8FChn1KU6w
      The idea is to place this code into a single cost field so that it will calculate costs depending on whether a checkbox is checked or not (returns "yes" or "no")
      Any ideas?  Also, for some unknown reason the RESET button keeps defaulting to the Mouse Up action - will not let me set it to Mouse Enter.  Why?
      var nCheck_bx = [Check_bx]
      var nMil1 = [MileageOne]
      var nMil2 = [MileageTwo]
      var nTotal = [TotalMiles]
      var nCost1 = [FirstCost]
      var nCost2 = [SecondCost]
      var nTSMC = [TotalStandard_Miles_Cost]
      if (nCheck_bx = "No" && [nMil1] = Null) {
      [nTSMC] = [nTotal]*[nCost1]
      else (nCheck_bx = "Yes" && [nMil1] > 0 && [nMil2] = Null) {
      [nTSMC] = [nMil1]*[StandardCost]+[nMil2]-[nMil1]*[nCost1]
      elseif ( nCheck_bx = yes && [nMil1] > 0 && [nMil2] > 0 ) {
      [nTSMC] = [nMil1]*[StandardCost]+[nMil2]-[nMil1]*[nCost1] + [CalcField3]*[nCost2]
      endif
        • 1. Re: Javascript help
          George_Johnson MVP & Adobe Community Professional
          There are a lot of things wrong with the code, and the document you linked to hasn't been published/shared properly so I can't examine it to help understand what it is you're trying to do. Is this a form you created in Acrobat or LiveCycle Designer?
          • 2. Re: Javascript help
            AffordableParalegal Level 1
            I'm sorry George, I thought that one was accessible. I am such a newbie with this - only second or third day here. LOTS of things wrong ..OMG . . then I am definitely in need of help -- or a psychologist LOL.  I will try to link to another document. I just save it as a pdf right? No special save technique?
            https://workspaces.acrobat.com/?d=i5IK6t5gCPGEz8OpS*i-vw
            OK - maybe this will work.
            • 3. Re: Javascript help
              I found this example which is about as close as I can come to the kind of syntax I may need.  I am going to assume I don't need html tags but just the <script> before and at the end? for starters. Correct? Next I see there is the use of eval function and Calc (can't find a syntax for this)  Do I have to convert the fields/objects to numbers? So I guess I can't just multiply one field by another? Ihave to call the number using Number() function?
              <html>
              <head>
              <title></title>
              function Calc(){
              //Validate here to see if the fields have a value
              //if yes, Validate here to see if the fields have a numeric value
              //if yes do the stuff below
              //repeat step for each box (each box must have a numeric value)
              VField1=eval(document.calcform.field1.value)
              VField2=eval(document.calcform.field2.value)
              VField3=eval(document.calcform.field3.value)
              document.calcform.field4output.value=VField1+VFiel d2+VField3
              </script>
              </head>
              <body>
              <form name="calcform">
              <input type=text name="field1" size="12"onchange="javascript:Calc();"><br>
              <input type=text name="field2" size="12"onchange="javascript:Calc();"><br>
              <input type=text name="field3" size="12"onchange="javascript:Calc();"><br>
              <input type=text name="field4output" size="12" readonly><br>
              <input type=button value="Add" onclick="javascript:Calc();" >
              </form>
              </body>
              </html>
              Message was edited by: AffordableParalegal
              • 4. Re: Javascript help
                Bernd Alheit Adobe Community Professional & MVP
                Don't mix browser Javascript and Acrobat Javascript. You may read the documentation for Acrobat Javascript.
                • 5. Re: Javascript help
                  You really can't just take an HTML script, delete a couple of things, and get a PDF script. There is nothing in this that could be salvaged. You need to move to the point where you understand each and every line in the script, what it does and why it is there (even if you couldn't write that line from scratch).
                  • 6. Re: Javascript help
                    But let's look at your questions, they are interesting.
                    The eval function is standard JavaScript, but is really for special purposes. Avoid it until you hit a wall that can only be solved that way.
                    Now, Calc is a function used in this script. Notice at the top
                    function Calc(){
                    ... some lines which won't work in Acrobat...
                    That defines a function called Calc, which can now be used to do work. You would write just Calc() to do that. (This example calls Calc() but not in a way valid in Acrobat). A function is just like writing out the stuff in the function every time it is used ("called") but is there to save time and avoid the mistakes which come from retyping. It's a really useful thing for beginners to learn early.
                    Here's an example of a function that calculates the average of three numbers
                    function AverageOf3(x,y,z)
                         var sum = x+y+z ;
                         var average = sum / 3 ;
                         return average;
                    Suppose you wanted the average of fields called f1, f2, and zoom in Acrobat. You could write
                    var f1=this.getField("f1") ;
                    var f2=this.getField("f2") ;
                    var zoom=this.getField("zoom") ;
                    var theaverage = AverageOf3(f1,f2,zoom) ;
