1. Re: Screwy DW after update
Sudarshan Thiagarajan Mar 12, 2013 12:06 AM (in response to therayman)It would have prompted you 'Update Links'? Only if you had clicked 'Yes', updation would have happened. Or else, maybe you had configured DW not to prompt you for this, hence, it has auto-updated.
Either way, can you check your Site definition settings to ensure your Local server info are not containing your remote parameters in them?
To change back, you could do Site > Change Link Sitewide to change all 'linked' pages with different relative paths.
2. Re: Screwy DW after update
therayman Mar 12, 2013 10:23 AM (in response to Sudarshan Thiagarajan)I don't use DW to upload to my remote server and it therefore only has local settings. I find that more controllable.
I don't use auto update but did want DW to update the links. That is not the problem it is simply what caused it.
The relative paths within the pages are correct and they work when uploaded. DW just doesn't recognize them.
Changing the links sitewide didn't actually change them because they were already correct. The problem appears to be within DW not the html.
Deleting the site and adding it again changed nothing. Adding the site on a different machine didn't solve the problem.
Going back in time in my backups to the point before moving the file enabled me to solve the problem.
Ray Parkes
Sent with Sparrow (http://www.sparrowmailapp.com/?sig)
