4 Replies Latest reply on Mar 13, 2013 3:12 AM by axelheimann
    Documentation about flashinstall.log
    axelheimann
      Hello,
      does exist a documentation about the contents of the FlashPlayer installation log file "flashinstall.log"?
      It could be interesting to understand the entries. Additionally the documentation of the error codes could help to find and fix installation/update problems...
      'til now, I haven't found any documentation about on Adobe pages. I found, how I can activate/deactivate logging, but nothing about the structure, the meanings, error codes, etc....
      Best Regards
      Axel
        • 1. Re: Documentation about flashinstall.log
          chris.campbell Adobe Employee
          There is no published info that I know of.  Are there particular entries that you are curious about?
          • 2. Re: Documentation about flashinstall.log
            axelheimann Level 1
            Thank you for your answer Chris.
            I'm interested in the general structure of this log, to understand in a better way, what's happen.
            What do the the different entries in the brackets mean, for example
            0006 [W] ...
            0007 [I] ...
            0008 [E] ...
            I'm interested in a list of the different error codes, for example the following one: (I've a lot of more, but this error appeard mostly in the logs, independent of a working FlashPlayer or not...)
            [error] 1223 1058
            Next info about the different parameters (?) of EXE, DLL or OCX entries which appear sometimes or not
            C:\Windows\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
            C:\Windows\system32\Macromed\Flash\FlashUtil32_11_5_502_135_ActiveX.exe 5
            C:\Windows\system32\Macromed\Flash\Flash32_11_5_502_135.ocx 5
            What do the numbers mean after the brackets, they are not continuous
            0000 [I] 00000010
            0001 [I] 00000020
            0002 [W] 00001015
            0003 [I] 00000018
            Why and how is it possible, that I can find a user profile path entry of an Flash-update in the log, no user has rights to install applications in our environment.
            Normally updates should be installed by local system (automatic) or admin...
            etc.
            I don't understand, why there exist no documentation about. There exist in several documents the hint, how to activate logging, but nowhere a description about the logs...
            Best regards
            Axel
            • 3. Re: Documentation about flashinstall.log
              pwillener Level 8
              Maybe Chris can provide more info, but the code in the brackets mean
              [I] = Information (correct)
              [W] = Warning (something wrong)
              [E] = Error (installation failed)
              The numbers at the end of a file (5, 183) indicate that the file could not be written or replaced (permission issue).
              I have never been able to figure out what the numbers after the bracketed code mean.
              • 4. Re: Documentation about flashinstall.log
                axelheimann Level 1
                Thank you Pat for the hints...
                It's interesting, if you receive a warning in the log without a hint about the problem... :-)
                I found this in a log, without any information behind the numbers or is it caused by the last entry?
                =O====== M/11.5.502.146 2013-01-23+15-12-36.708 ========
                0000 [I] 00000010 "C:\Program Files\LANDesk\LDClient\sdmcache\install_flash_player_ax_32bit_11.5.502.146.exe" -install
                0001 [I] 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0002 [I] 00000013 C:\WINDOWS\system32\Macromed\Flash\Flash32_11_5_502_146.ocx
                0003 [I] 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.exe
                0004 [I] 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil32_11_5_502_146_ActiveX.dll
                0005 [I] 00000023 C:\WINDOWS\system32\Macromed\Flash\activex.vch
                0006 [I] 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
                0007 [W] 00001024 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl 183
                0008 [W] 00001024 C:\WINDOWS\system32\FlashPlayerApp.exe 183
                0009 [I] 00000021 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe
                0010 [W] 00001106
                0011 [W] 00001106
                0012 [W] 00001024 C:\WINDOWS\system32\Macromed\Flash\FlashPlayerUpdateService.exe 183
                =X====== M/11.5.502.146 2013-01-23+15-12-43.318 ========
                FlashPlayer was installed with success and running! But 'til this day, the log entries are changed in this way:
                2013-1-23+15-20-1.453 [error] 1223 1058
                2013-1-24+12-20-15.250 [error] 1223 1058
                2013-1-24+13-20-15.93 [error] 1223 1058
                2013-1-24+14-20-15.93 [error] 1223 1058
                2013-1-24+15-20-15.93 [error] 1223 1058
                2013-1-24+16-20-15.109 [error] 1223 1058
                2013-1-25+7-20-15.484 [error] 1223 1058
                2013-1-25+8-20-0.261 [error] 1223 1058
                2013-1-25+9-20-0.432 [error] 1223 1058
                2013-1-25+10-20-0.248 [error] 1223 1058
                2013-1-25+11-20-0.459 [error] 1223 1058
                2013-1-25+12-20-0.584 [error] 1223 1058
                2013-1-25+13-20-0.443 [error] 1223 1058
                2013-1-25+14-20-0.257 [error] 1223 1058
                2013-1-25+15-20-0.501 [error] 1223 1058
                2013-1-28+8-20-15.671 [error] 1223 1058
                2013-1-28+9-20-15.78 [error] 1223 1058
                2013-3-12+12-20-15.93 [error] 1223 1058
                2013-3-12+13-20-0.109 [error] 1223 1058
                2013-3-12+14-20-0.62 [error] 1223 1058
                2013-3-13+9-20-15.578 [error] 1223 1058
                Client was offline a while, so no newer update was installed :-) but I will soon, if I understand the error messages...
                Regards
                Axel
