0 Replies Latest reply on Mar 12, 2013 1:21 PM by joe_valenzuela
    Error #1034 Type Coercion fail with registerClassAlias and nested Vectors
    joe_valenzuela
      I'm attempting to use flash.net.registerClassAlias and ByteArray.writeObject in order to serialize/deserialize data with static type information.  It works as you'd expect in the general case but I've run into problems with some nested Vectors that I don't understand.  Hopefully someone can point out if I'm just missing something.
      For what I understand, we must register both the scalar types and a one-deep specification of a Vector for that scalar type in order to use nested Vectors.  For example:
                  flash.net.registerClassAlias("TestStructureInner", TestStructureInner);
                  flash.net.registerClassAlias("VectorTestInner", Vector.<TestStructureInner> as Class);
      This should allow us to read/write objects of type TestStructureInner, Vector.<TestStructureInner>, and Vector.<Vector.<TestStructureInner>> into ByteArrays.  And in general it seems to work.
      Attached though is a simplified test case that fails, however.  The first time we deserialize the data it works.  The subsequent time, however, we encounter the following runtime error #1034.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304fcb9 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304fbc9 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304fdd1 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304fce1 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304fbf1 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304fec1 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304fad9 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304fa61 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304f9e9 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
          TypeError: Error #1034: Type Coercion failed: cannot convert __AS3__.vec::Vector.<Object>@304f971 to __AS3__.vec.Vector.<__AS3__.vec::Vector.<Test0.as$30::TestStructureInner>>.
      Re-registering the class aliases again via flash.net.registerClassAlias works in this test case but isn't 100% for our actual application (I'm reticent to even mention it but it seems relevant).  Is there a step I'm missing here?  Any light shed would be appreciated.
      // mxmlc -debug Test0.as
      package
          import Base64; // http://code.google.com/p/jpauclair-blog/source/browse/trunk/Experiment/Base64/src/Base64.a s
          import flash.net.registerClassAlias;
          import flash.events.Event;
          import flash.utils.ByteArray;
          import flash.display.Sprite;
          import flash.display.Stage;
          import flash.system.System;
          public class Test0 extends Sprite
              static private const OPERATION_SERIALIZE:uint = 0;
              static private const OPERATION_DESERIALIZE_AND_FAIL:uint = 1;
              static private const OPERATION_DESERIALIZE_AND_SUCCEED:uint = 2;
              static private var staticStage:Stage;
              private var bar:Vector.<TestStructure>;
      * common functions
              static private function registerClassAliases():void
                  flash.net.registerClassAlias("TestStructure", TestStructure);
              static public function staticDeserialize():Object
                  var byteArray:ByteArray = Base64.decode("EBUAG1Rlc3RTdHJ1Y3R1cmUKEwAHZm9vEAEAH1ZlY3RvclRlc3RJbm5lcgoBEAEABAoBEAEABA oBEAEABAoBEAEABAoBEAEABAoBEAEABAoBEAEABAoBEAEABAoBEAEABA==");
                  byteArray.position = 0;
                  return byteArray.readObject();
              public function Test0():void
                  registerClassAliases();
                  // Switching operation between the constants demonstrates failure/success in a couple of different ways.
                  // SERIALIZE is just used to prepare the base64 string for subsequent tests.
                  var operation:int = OPERATION_SERIALIZE_AND_FAIL;
                  if (operation == OPERATION_SERIALIZE)
                      trace("Serializing");
                      // outputs base64 string for subsequent tests
                      serialize();
                  else if (operation == OPERATION_DESERIALIZE_AND_FAIL)
                      trace("Fail case");
                      // perform successful one deserialization, then one failing one.
                      deserializeOnceThenFail();
                  else if (operation == OPERATION_DESERIALIZE_AND_SUCCEED)
                      trace("Success via re-registration");
                      // perform successful one deserialization, then another successful one.
                      deserializeOnceThenSucceed();
      * serialize
              // outputs base64 string we use for subsequent tests.
              private function serialize():void
                  var baz:Vector.<TestStructure> = new Vector.<TestStructure>;
                  for (var i:int=0; i<10; ++i)
                      baz.push(new TestStructure);
                  var byteArray:ByteArray = new ByteArray;
                  byteArray.writeObject(baz);
                  trace(Base64.encode(byteArray));
      * deserializeOnceThenFail
              public function deserializeOnceThenFail():void
                  // save stage
                  staticStage = stage;
                  // the first deserialize will proceed without error.
                  staticDeserialize();
                  trace("Successful deserialize");
                  // add an event listener in order to invoke error on subsequent frame
                  stage.addEventListener(Event.ENTER_FRAME, doEnterFrameOnceThenFail);
              // remove event listener and invoke again.
              static private function doEnterFrameOnceThenFail(e:Event):void
                  staticStage.removeEventListener(Event.ENTER_FRAME, doEnterFrameOnceThenFail);
                  trace("unsuccessful deserialize2");
      * deserializeOnceThenSucceed
      * Here, we re-call flash.net.registerClassAlias on all our class types when running.
              public function deserializeOnceThenSucceed():void
                  // save stage
                  stage.addEventListener(Event.ENTER_FRAME, doEnterFrameOnceThenSucceed);
              static private function doEnterFrameOnceThenSucceed(e:Event):void
                  staticStage.removeEventListener(Event.ENTER_FRAME, doEnterFrameOnceThenSucceed);
                  trace("successful deserialize2");
      internal class TestStructureInner
                public var value:int;
                public var foo:Vector.<Vector.<TestStructureInner>> = new Vector.<Vector.<TestStructureInner>>;
