1. Re: CS6 Info Palette and Group Adjustment Layer Bug
gwlsn Mar 12, 2013 5:24 PM (in response to gwlsn)Additionally, this problem occurs in RGB, Grayscale, CMYK and LAB.
Photoshop 13.0.4
2. Re: CS6 Info Palette and Group Adjustment Layer Bug
Noel Carboni Mar 12, 2013 6:17 PM (in response to gwlsn)I believe I understand what you're talking about (numbers to the left of the / and numbers to the right).
For what it's worth, on my PC in 13.1.2 if I choose a single adjustment layer I see BBB / AAA numbers.
But if I choose two adjustment layers, or a group containing the adjustment layers, or all of the layers AND the group I do not see BBB / AAA - there's just one set of numbers shown.
-Noel
3. Re: CS6 Info Palette and Group Adjustment Layer Bug
gwlsn Mar 13, 2013 3:12 PM (in response to Noel Carboni)yes, when adding an adjustment layer inside of a group, the info pallet will display the corrected value on the left and right (bbb/bbb)
instead of the uncorected value on the left next to the corrected value on the right (aaa/bbb)
when the adjustment layer is not inside of a group, the info pallet functions as normal.
its odd that two of our macs function correctly while two do not.
4. Re: CS6 Info Palette and Group Adjustment Layer Bug
EricAtArtisan Apr 9, 2013 11:58 AM (in response to gwlsn)I am also having this issue. It works on my MacBook, but not my iMac. The only difference I see is that my MacBook is running 13.0 Extended, but the problem iMac is running 13.0.4 Standard. On the problem computer I have tried logging in as a new user (clean prefs) and the issue still exists. I've tried changing profiles, preview and proof settings with no difference. I've also tried different eyedropper settings (current layer, all layers, etc) with no difference. If I drag the correction layer out of the group, the readings show correctly. If I move them back INTO the group, they only show the corrected values. Very odd.
Problem computer specs:
Photoshop CS6 Standard (13.0.4 x64)
iMac 21.5" 2.7GHz quad-core Intel Core i5
16 GB 1600MHz DDR3
NVIDIA GeForce GT 640M 512M
OSX Mountain Lion 10.8.3
Working computer specs:
Photoshop CS6 Extended (13.0 x64)
MacBook Pro 17-inch, Mid 2010 2.53 GHz Intel Core i5
8 GB 1067 MHz DDR3
NVIDIA GeForce GT 330M 512 MB
OSX Mountain Lion 10.8.2
