1 Reply Latest reply on Mar 12, 2013 6:24 PM by Noel Carboni
    Can't use Canon scanner.
    Joe_Caldwell Level 1
      Hi, All.
      I've tried installing a CanoScan Lide 200 scanner to be used with Photoshop CS6 but can't seem to make it work. I downloaded the two latest drivers available on Canon's website and installed them but it hasn't worked.
      Do any of you know if there are special steps that need to be taken to make this scanner work with Photoshop CS6 ?
      Thank you in advance.
        • 1. Re: Can't use Canon scanner.
          Noel Carboni Level 8
          Are you running Photoshop CS6 32 bit, specifically?  What OS are you running?
          As far as I know scanning into Photoshop directly via TWAIN is possible only in the 32 bit version, and only then when the Adobe optional Twain_32.8ba plug-in has been loaded.
          There may have been some more recent additions where something like WIA might provide scanning support; I'm not sure.  It's been a while since I've had a scanner; nowadays I just photograph things I want scans of with my dSLR.
          -Noel
