1 Reply Latest reply on Mar 13, 2013 1:18 AM by Peter Spier
    Grep Styles
    gfpimentel
      How to change this two lines formatted with Bold, regular and italic, and change it to all bold in Grep Style.
      I need to do it several times, but how to get the right script in grep to find Bold face at the beginning then a tab
      then a regular 11 pts and return plus tab and italic text in parenthesis, see example below:
      P. 1.  ¿Cuán cierta y segura será la segunda venida de Cristo?
               (Hebreos 9:28)
        • 1. Re: Grep Styles
          Probably not a candidate for a GREP style. GREP styles are used to apply character styles to text matching the Query string. This looks, at least to me, as if you want to apply a paragraph style. You could maybe use a find/change GREP query to do that, but you can't base it on multiple formatting, only the pattern in the text itself.
          Right now, if I had to guess, I would say there is a paragraph style applied that uses either a numbered list (can you select the P.1. ?) and a nested style, or two nested styles to make the page number bold and the verse italic. If that's the case, you might be able to just re-define the style.
          Do you really want to remove the italics, or make them bold italics? Do all the paragraphs start with P. and a digit or digits and end at the closing parenthesis?
