4 Replies Latest reply on Mar 13, 2013 3:09 AM by Test Screen Name
    HELP WITH JAVA SCRIPT
    HARISH_JANGIR
      Hi Experts..
      I have a Visual Basic Script To Convert Number into word(text) in indian format. i using this script in Excel ,but i want to use in abode Acrobat Form. how is this Possible ?
      I request to you Plz Make a java Script like this Script.
      Thank You
      MY SCRIPT IS HERE
      Function SpellNumber(ByVal MyNumber, Optional incRupees As Boolean = True)
      Dim Crores, Lakhs, Rupees, Paise, Temp
      Dim DecimalPlace As Long, Count As Long
      Dim myLakhs, myCrores
      ReDim Place(9) As String
      Place(2) = " Thousand ": Place(3) = " Million "
      Place(4) = " Billion ": Place(5) = " Trillion "
      ' String representation of amount.
      MyNumber = Trim(Str(MyNumber))
      ' Position of decimal place 0 if none.
      DecimalPlace = InStr(MyNumber, ".")
      ' Convert Paise and set MyNumber to Rupees amount.
      If DecimalPlace > 0 Then
      Paise = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2))
      MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
      End If
      myCrores = MyNumber \ 10000000
      myLakhs = (MyNumber - myCrores * 10000000) \ 100000
      MyNumber = MyNumber - myCrores * 10000000 - myLakhs * 100000
      Count = 1
      Do While myCrores <> ""
      Temp = GetHundreds(Right(myCrores, 3))
      If Temp <> "" Then Crores = Temp & Place(Count) & Crores
      If Len(myCrores) > 3 Then
      myCrores = Left(myCrores, Len(myCrores) - 3)
      Else
      myCrores = ""
      End If
      Count = Count + 1
      Loop
      Count = 1
      Do While myLakhs <> ""
      Temp = GetHundreds(Right(myLakhs, 3))
      If Temp <> "" Then Lakhs = Temp & Place(Count) & Lakhs
      If Len(myLakhs) > 3 Then
      myLakhs = Left(myLakhs, Len(myLakhs) - 3)
      Else
      myLakhs = ""
      End If
      Count = Count + 1
      Loop
      Count = 1
      Do While MyNumber <> ""
      Temp = GetHundreds(Right(MyNumber, 3))
      If Temp <> "" Then Rupees = Temp & Place(Count) & Rupees
      If Len(MyNumber) > 3 Then
      MyNumber = Left(MyNumber, Len(MyNumber) - 3)
      Else
      MyNumber = ""
      End If
      Count = Count + 1
      Loop
      Select Case Crores
      Case "": Crores = ""
      Case "One": Crores = " One Crore "
      Case Else: Crores = Crores & " Crores "
      End Select
      Select Case Lakhs
      Case "": Lakhs = ""
      Case "One": Lakhs = " One Lakh "
      Case Else: Lakhs = Lakhs & " Lakhs "
      End Select
      Select Case Rupees
      Case "": Rupees = "Zero "
      Case "One": Rupees = "One "
      Case Else:
      Rupees = Rupees
      End Select
      Select Case Paise
      Case "": Paise = " and Paise Zero Only "
      Case "One": Paise = " and Paise One Only "
      Case Else: Paise = " and Paise " & Paise & " Only "
      End Select
      SpellNumber = IIf(incRupees, "Rupees ", "") & Crores & _
      Lakhs & Rupees & Paise
      End Function
      ' Converts a number from 100-999 into text
      Function GetHundreds(ByVal MyNumber)
      Dim Result As String
      If Val(MyNumber) = 0 Then Exit Function
      MyNumber = Right("000" & MyNumber, 3)
      ' Convert the hundreds place.
      If Mid(MyNumber, 1, 1) <> "0" Then
      Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred "
      End If
      ' Convert the tens and ones place.
      If Mid(MyNumber, 2, 1) <> "0" Then
      Result = Result & GetTens(Mid(MyNumber, 2))
      Else
      Result = Result & GetDigit(Mid(MyNumber, 3))
      End If
      GetHundreds = Result
      End Function
      ' Converts a number from 10 to 99 into text.
      Function GetTens(TensText)
      Result = "" ' Null out the temporary function value.
      If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19...
      Select Case Val(TensText)
      Case 10: Result = "Ten"
      Case 11: Result = "Eleven"
      Case 12: Result = "Twelve"
      Case 13: Result = "Thirteen"
      Case 14: Result = "Fourteen"
      Case 15: Result = "Fifteen"
      Case 16: Result = "Sixteen"
      Case 17: Result = "Seventeen"
      Case 18: Result = "Eighteen"
      Case 19: Result = "Nineteen"
      Case Else
      End Select
      Else ' If value between 20-99...
      Select Case Val(Left(TensText, 1))
      Case 2: Result = "Twenty "
      Case 3: Result = "Thirty "
      Case 4: Result = "Forty "
      Case 5: Result = "Fifty "
      Case 6: Result = "Sixty "
      Case 7: Result = "Seventy "
      Case 8: Result = "Eighty "
      Case 9: Result = "Ninety "
      Case Else
      End Select
      Result = Result & GetDigit _
      (Right(TensText, 1)) ' Retrieve ones place.
      End If
      GetTens = Result
      End Function
      ' Converts a number from 1 to 9 into text.
      Function GetDigit(Digit)
      Select Case Val(Digit)
      Case 1: GetDigit = "One"
      Case 2: GetDigit = "Two"
      Case 3: GetDigit = "Three"
      Case 4: GetDigit = "Four"
      Case 5: GetDigit = "Five"
      Case 6: GetDigit = "Six"
      Case 7: GetDigit = "Seven"
      Case 8: GetDigit = "Eight"
      Case 9: GetDigit = "Nine"
      Case Else: GetDigit = ""
      End Select
      End Function
