1 Reply Latest reply on Mar 10, 2015 2:47 PM by rskdbl
    ASC 2.0 Compiler warnings about not found definitions in SWCs?
    sascha/hdrs
      Since using the AIR SDK 3.6 with ASC 2.0 when I try to compile one of my Flash for web projects it gives me plenty of compiler warnings about AS3 API that is compiled in additional SWCs which is part of the AIR supported API but not supported in the Flash Player. The former compiler didn't have any trouble with this. How can I disable these warnings?
      Here's an excerpt of the 100s of warnings:
         [mxmlc] E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc
         [mxmlc] Warning: The definition flash.display.NativeWindowSystemChrome depended on by com.hexagonstar.update.descriptors.ApplicationDescriptor in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.filesystem.File depended on by com.hexagonstar.update.descriptors.StateDescriptor in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.display.NativeWindowType depended on by com.hexagonstar.update.ui.UpdateUIWrapper in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.display.NativeWindowSystemChrome depended on by com.hexagonstar.update.ui.UpdateUIWrapper in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.desktop.NativeApplication depended on by com.hexagonstar.update.ui.UpdateUIWrapper in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.display.NativeWindow depended on by com.hexagonstar.update.ui.UpdateUIWrapper in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.display.NativeWindowInitOptions depended on by com.hexagonstar.update.ui.UpdateUIWrapper in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.filesystem.File depended on by com.hexagonstar.update.core.UpdaterState in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.filesystem.File depended on by com.hexagonstar.update.utils.FileUtils in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.filesystem.FileMode depended on by com.hexagonstar.update.utils.FileUtils in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
         [mxmlc] Warning: The definition flash.filesystem.FileStream depended on by com.hexagonstar.update.utils.FileUtils in the SWC E:\Projects\Eclipse\com.hexagonstar.libs.tetragon\libs\swc\appupdater.swc could not be found
