4 Replies Latest reply on Mar 14, 2013 1:07 PM by George_Johnson
    Signing multiple PDfs with Adobe esig
    Cmillermicrocheck
      Hello,
      I am trying to sign thousands of documents with my electronic signiture. They are scanned documents that I have verified are true and exact copies. The problem is that each document has a cover page with a signiture field and I must double click type password and fill in reason for every page. I am trying to Batch this right now using java script in the batch processing section.
      I saw online that there is a way to sign multiple documents using java but I am not sure if that is for Adobe acrobat 9 or not.
      I was experimenting with this
      Sign all documents
      Batch sequence name:Signature Sign All.sequ
      Task: Create an invisible signature on each of the selected files.
      Example 2.12
      Sign all documents
      /* Signature Sign All */
      // Choose handler
      var ppklite = security.getHandler("Adobe.PPKLite");
      // Login -- change as appropriate
      ppklite.login("dps017", "/C/Profiles/DPSmith.pfx");
      // Add a signature field with zero dimensions (invisible)
      var f = this.addField("Signature", "signature", 0, [0,0,0,0]);
      // Sign it and log out. Change as appropriate
      f.signatureSign(ppklite,
      { password: "dps017",
      reason: "I am approving this document",
      contactInfo: "dpsmith@mycompany.com",
      appearance: "DPSmith"});
      ppklite.logout();
      I tried filling in my information....  It gets stuck at the handler part. If someone could explain to me what things are generic here that I need to fill in with my info and where I may find that info. I know that // are comments, but some of this info is over my head. I would be extremely grateful if someone could help me figure this out as it would save me countless hours of clicking and signing.
      Chris
        • 1. Re: Signing multiple PDfs with Adobe esig
          George_Johnson MVP & Adobe Community Professional
          It can be made much simpler if you set up your signature to not require that you log-in. The entire script can then be reduced to just:
          addField("Signature", "signature", 0, [0,0,0,0]).signatureSign();
          To set it up so you don't have to log-in, open the Security Settings dialog, select "Digital ID Files" in the panel on the left, and click the "Password Timeout" button:
          Then select something other than "Always", such as Once per session or Never:
          You can change it back once you've added the signatures if you want.
          • 2. Re: Signing multiple PDfs with Adobe esig
            Also, to get to the Security Setting dialog in Acrobat 9, select: Advanced > Security Settings
            • 3. Re: Signing multiple PDfs with Adobe esig
              Cmillermicrocheck Level 1
              Okay that is very useful.
              I have a signiture field already on the first page of each document do I delete that?
              This will still use my name.pfx when signing?.
              Do I modify the zeros to place the signiture somewhere?
              I also still need to have the I am approving this document in there. Do I add this like before?
              I really appreciate this!
              • 4. Re: Signing multiple PDfs with Adobe esig
                If you already have a signature field in place that you want to use, the code can be changed to:
                getField("your_signature_field_name").signatureSign();
                The other code automatically adds a signature field and since the width and height are zero, it is not visible on the page. If you want to provide a specific reason, just include it like the other code above shows:
                getField("your_signature_field_name").signatureSign({reason: "Your reason goes here."});
