2 Replies Latest reply on Mar 15, 2013 5:34 AM by AWBUND1
    XPath Builder location?
      Probably a stupid question but I am new to Workbench. I have searched to see if this question already exists.
      I'm in Process Designer view in workbench for a Process.
      I double click on a Set Value item to bring up the Process Properties.
      I expand Mappings and see the current Mappings.
      I click Edit the mapping Data button and nothing happens.
      I need to add a new mapping and searching Help seems to suggest this is done in the XPath Builder, but I cant find it anywhere? Do I need to install it as an add-in to Workbench?
      Any help appreciated.
        • 1. Re: XPath Builder location?
          AWBUND1 Level 1
          Using Workbench 10.0.01 if it makes any difference.
          • 2. Re: XPath Builder location?
            AWBUND1 Level 1
            Additionally this is the screen I'm on:
            But I cant get Edit mappings button to work? Looks like it tries to execute something when I click it but nothing happens.
            Also the error that I've found in the Workbench error log when you click the Edit mappings button is:
            !ENTRY com.adobe.workflow.editor 4 0 2013-03-15 12:32:51.489
            !MESSAGE Failed to set schema source!
            !STACK 0
            java.lang.IllegalArgumentException: Invalid absolute path:
            at com.adobe.livecycle.workbench.common.service.internal.ApplicationManagerImpl.resolveResou rcePath(ApplicationManagerImpl.java:346)
            at com.adobe.livecycle.workbench.common.service.internal.ApplicationManagerImpl.getResource( ApplicationManagerImpl.java:283)
            at com.adobe.workflow.eclipse.utils.template.ProcessTemplateUtil.convert2Document(ProcessTem plateUtil.java:194)
            at com.adobe.workflow.eclipse.dialogs.XPathBuilderDialog.fillProcessTree(XPathBuilderDialog. java:1604)
            at com.adobe.workflow.eclipse.dialogs.XPathBuilderDialog.createDialogArea(XPathBuilderDialog .java:1248)
            at org.eclipse.jface.dialogs.TitleAreaDialog.createContents(TitleAreaDialog.java:155)
            at org.eclipse.jface.window.Window.create(Window.java:431)
            at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
            at org.eclipse.jface.window.Window.open(Window.java:790)
