1 Reply Latest reply on Mar 14, 2013 4:32 PM by George_Johnson
    folder level script error for creating a button - help
    mosinitis
      -Using Acrobat X Pro on Windows 7 64bit -
      So I'm trying to create a folder level script that creates a toolbar button, which when pressed will flatten the pdf and save it.  My problem is that when I run it on one certain PDf, it will flatten the pdf, but not save it. When I run it in any other pdfs I get this error:
      NotAllowedError: Security settings prevent access to this property or method.
      Doc.flattenPages:4:App TestingButton:Exec
      Here is my code for the folder level javascript
      app.addToolButton({cName: "TestingButton", cLabel: "Test Button", cEnable: "event.rc = (app.doc != null);", cExec: "proccessTicket();" });
      var proccessTicket = function() {
      this.flattenPages();
      app.execMenuItem("Save");
      Also, I'm not sure I've done the "var proccessTicket" correctly.  It doesn't seem to be saving the pdf when I perform it in the ond pdf that the script will work in.
      Also, how do I get this to show up automatically at startup in the quick tools toolbar section rather than in the pane on the right.
      Any ideas? Thanks in advance.
      Trey
