4 Replies Latest reply on Mar 14, 2013 8:03 PM by CarlosCanto
    finding the matrix info on a text frame?
    DuanesSearchForKnowledge Level 1
      I wanted to understand the matrix values and methods so I could make a script to select or not select textframes that are angled.
      Can anyone explain this matrix stuff to me?
      This script is the only example I have found so far.
      if ( app.documents.length > 0 ) {
      var moveMatrix = app.getIdentityMatrix( 0.5, 1.5 );
      var totalMatrix = concatenateRotationMatrix( moveMatrix, 10 );
      var doc = app.activeDocument.activeLayer;
      for ( i = 0; i < doc.pageItems.length; i++ ) {
      doc.pageItems[i].transform( totalMatrix );
      Im thinking I need to use getRotationMatrix([angle])
      any help would be greatly appreciated,
      Duane
        • 1. Re: finding the matrix info on a text frame?
          CarlosCanto Adobe Community Professional & MVP
          here's another example using matrix properties
          var idoc = app.activeDocument;
          var itext = idoc.textFrames[0];
          var imatrix = itext.matrix;
          $.writeln(imatrix.mValueA+"\r"+imatrix.mValueB+"\r"+imatrix.mValueC+"\r"+imatrix.mValueD+"\r"+imatrix.mValueTX+"\r"+imatrix.mValueTY);
          if (imatrix.mValueA !=1 || imatrix.mValueB !=0)
              alert('rotated');
          else
              alert('unrotated');
          • 2. Re: finding the matrix info on a text frame?
            Thanks Carlos!!!
            Hey Carlos, what does the $ mean?
            • 3. Re: finding the matrix info on a text frame?
              Awesome Carlos!
              This deselects all angle text in my selection.
                  Deselects all angle text from selection
              function deselectAllAngleTextFromSelection() {
                  var mydoc = app.activeDocument;
                  var mytext = idoc.textFrames;
                      for (i =0; i < mytext.length; i++) {
                              var mytextFrames = mydoc.textFrames[i];
                              var theMatrix = mytextFrames.matrix;
                              $.writeln(theMatrix.mValueA+"\r"+theMatrix.mValueB+"\r"+theMatrix.mValueC+"\r"+theMatrix. mValueD+"\r"+theMatrix.mValueTX+"\r"+theMatrix.mValueTY);
                                  if (theMatrix.mValueA !=1 || theMatrix.mValueB !=0) {
                                      mytextFrames.selected = false;
              deselectAllAngleTextFromSelection();
              Thanks much,
              Duane
              • 4. Re: finding the matrix info on a text frame?
                Hi Duane, from the Guide
                Dollar ($) object
                This global ExtendScript object provides a number of debugging facilities and informational methods. The
                properties of the $ object allow you to get global information such as the most recent run-time error, and
                set flags that control debugging and localization behavior. The methods allow you to output text to the
                JavaScript Console during script execution, control execution and other ExtendScript behavior
                programmatically, and gather statistics on object use.
                $.writeln use is similar to "alert" but instead of showing what you want in a "window" it writes the results to the estk console...check the Tools Guide, page 216.
                if the estk is closed the script will open it to write to the console, so comment that line to avoid that.
