3 Replies Latest reply on Mar 15, 2013 4:42 PM by try67
    Copy button on every page w/ Javascript
    choprils
      Hi, im creating a presentantion PDF with a few buttons that i want to repeat on every page.
      Im already setting their function using javascript, see:
      var bt1 = this.getField("sair.Page 1");
      bt1.setAction("MouseUp", "app.fs.isFullScreen = false;");
      bt1.delay = false;
      var bt2 = this.getField("tela.Page 1");
      bt2.setAction("MouseUp", "app.fs.isFullScreen = true;");
      bt2.delay = false;
      var bt3 = this.getField("indice.Page 1");
      bt3.setAction("MouseUp", "this.pageNum = 1;");
      bt3.delay = false;
      app.fs.clickAdvances = false;
      What i want to do is to copy this 3 buttons to every other page on the document using Javascript, instead of doing it manually.
      I found the code below on JavaScript™ for Acrobat® API Reference, but i could not figure out how to apply this to my case.
      Since the buttons are not created via script, only their functions.
      Copy a given annotation to every page in the document.
      var annot = this.addAnnot({
      page: 0,
      type: "Text",
      rect: [40, 40, 140, 140]
      // Make a copy of the properties of annot
      var copy_props = annot.getProps();
      // Now create a new annot with the same properties on every page
      var numpages = this.numPages;
      for (var i=0; i < numpages; i++) {
      var copy_annot = this.addAnnot(copy_props);
      // but move it to page i
      copy_annot.page=i;
      Thanks in advance
        • 1. Re: Copy button on every page w/ Javascript
          George_Johnson MVP & Adobe Community Professional
          There is no similar method for copying a field programmatically. You can either use the doc.addField method to add a field to the pages and then set its properties or spawn a hidden template page that just contains the buttons as an overlay on each page.
          Out of curiosity, why are you including this: bt1.delay = false;
          • 2. Re: Copy button on every page w/ Javascript
            choprils Level 1
            I will give it a try! Thanks
            I dont know the correct use of the delay=false;
            Im just a graphic designer, and i have done this only by reading the examples of the API, my intention was just to make sure there was no delay in the script execution. That seemed important
            • 3. Re: Copy button on every page w/ Javascript
              If you want an exact copy of a button on multiple pages the easiest way to
              do it is to go to Form Edit mode, then right-click the button and select
              Duplicate. Then you enter the page range to duplicate to, and you're done.
              No scripts required.
              If you really want to do it with a script you'll need to use the addField
              method, as was described earlier.
