3 Replies Latest reply on Mar 25, 2013 2:27 PM by kab2013
    Need 2nd attempt to be different questions
    kab2013
      I have a 10 questions final quiz that people need to get an 80% on. If they fail I want them to take a completely different set of 10 questions. How do I do this?
        • 1. Re: Need 2nd attempt to be different questions
          VikramGaur Adobe Employee
          Hello,
          Welcome to Adobe Forums.
          Assuming you are using Adobe Presenter 8, you can use Question Group to achieve this functionality.
          1) Click on Adobe Presenter Tab, on your PPT
          2) Click on Manager under Quiz section, you will see this :
          3) Click on "Add Question Group"
          4) Once a group is added, add questions in it.
          Vikram
          • 2. Re: Need 2nd attempt to be different questions
            Vikram@Adobe Level 1
            This is possible by using option --  Manage quiz (on presenter ribbon) > quiz edit > Pass or Fail Option tab.
            Here you have to set the action (goto slide ) of 'If passing grade' and similarly for the failing grade.
            You have to add some unique set of 10 questions, each 10 questions can be in a quiz or question group, then use the above option to point the user to end slide, if user passes. Otherwise, point the user to next quiz/quiz group start slide.
            Vikram
            Adobe Presenter Engg. Team
            • 3. Re: Need 2nd attempt to be different questions
              kab2013 Level 1
              Thanks! I set-up the question group, but I also had to set-up a slide in between the two quizzes. I had the 1st question end on the interim slide and then that slide started the 2nd quiz.
