2 Replies Latest reply: Nov 14, 2007 1:07 PM by DanelKirch RSS
    XMLConnector problem
    DanelKirch Community Member
      Hi again :P
      im using XML connector in my project for listing some data from php/xml file.
      The thing is that i want to use a simpler way to configurate my project (im gonna publish the project for dowload) and instead of going into the fla file, to change the XMLconnector URL i need my project to scan a textfile for variables.
      now, i tested a lot of way, but cant seem to get over the problem. so, how do i give XML connector a URL in the AS2.0 instead of giving it in the parameters tab ?
      i tried mostly this way without any results:
      feed. load(list_address);
      and its defined in the textfile
      list_address=http://localhost/nmsos01/nmsos.php
        • 1. Re: XMLConnector problem
          here is the code im trying to get in work
          loadVariables("listing_ad.conf", this);
          this.feed.URL = "listing_ad";
          and if i test my movie with this code i get this:
          Error opening URL 'file:///F|/www/NMSos01/'
          its not the file i want to access its the URL where XMLconnector (feed) gets all the data from.
          • 2. XMLConnector problem
            problem again :((((
            im going with this code in actions layer
            loadVariablesNum("list_ad.conf", this);
            and my textfile (list_ad.conf) contains this
            listing_ad=http://localhost/NMSos01/Nmsos.php
            Now the problem is that i get this error in testing my movie
            Error opening URL 'file:///F|/www/NMSos01/listing_ad'
            AND i discovered in FF a open tab with adress to this text file.
            Anyone have any ideas ? it could help out alot.
