• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
CFC Question
Participant ,
Nov 15, 2007 Nov 15, 2007
Can you specify which database fields you want returnd to you when calling a CFC?
Let's say I have a employee table with 50 fields in it. I only want the first_name and last_name fields when I call a function GETNAME within my employee.cfc using EmpID as my argument.
Can I specify the first_name and last_name as arguments to be returned to me? if so, how?
TOPICS
Advanced techniques
Views
621
Translate
Translate
Report
Report
Community guidelines
community guidelines
Participant , Nov 15, 2007 Nov 15, 2007
Excellent.
Let me try it and see if I can get it working.
Thanks so much.
Votes
Translate
Translate
Advisor ,
Have the function in your CFC return a query object or a struct containing first and last name elements.
Votes
Translate
Translate
Report
Report
Participant ,
Thank Bob,
I was actually thinking of making it generic enough so if the requestor wanted "Last_name" and "Dept", then I would return that and if they wanted "Dept" and "Manager_Name", then I would return that. So the caller of the cfc would be in control and ask for what field they want.
So is there a way to tell the object what you want to have returned back?
Votes
Translate
Translate
Report
Report
Advisor ,
You could provide the field names desired as an array in an argument then build the query as shown below. I do not recommend this however as you are vulnerable to SQL injection attack unless you are careful about what gets into your array.
Votes
Translate
Translate
Report
Report
Advisor ,
Alternatively if you only execpt one row to be returned you could use a struct to return only the fields you desire.
See below
Votes
Translate
Translate
Report
Report
Participant ,
Thanks Bob,
What you have provided me is great.
Would I then call my cfc using the code below?
How would I know what the developer is going to be asking for? I need a way for them to tell me from the <cfinoke> in order for the CFC to know what to return. The calling part is what is puzzling me. The ability to accept different field name from the caller and send them back what they asked for.
Votes
Translate
Translate
Report
Report
Advisor ,
See code below
Votes
Translate
Translate
Report
Report
Participant ,
Excellent.
Thanks so much.
Votes
Translate
Translate
Report
Report
Guide ,
Minor typo correction. Don't forget to VAR the function variables :-)
<cfset VAR local=StructNew() />
Votes
Translate
Translate
Report
Report
Advisor ,
LATEST
Good catch cf_dev2. Yes, always var scope within cffunction.
Votes
Translate
Translate
Report
Report
Resources
Documentation
