• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Running .exe flash file in Windows 7
New Here ,
Mar 16, 2013 Mar 16, 2013
we have a flash .exe file generated from adobe_captivate5.5.I tried to run that file in windows 7.This error is coming
My account has administrative previlege.If i right click and select run as administrator it runs fine.But i need to run without doing that.Why its asking for run as administrator although i have administartor permission?how to avoid this?
Thank you
Views
4.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
This is because of Windows 7 security settings.
If you simply want to click the icon without having to use right mouse button and selecting Run as Administrator, you can set the file to execute with admin privileges by default.
1) Right click the icon, select Properties
2) Switch to Compatibility tab
3) At the bottom there is a "Run as administrator" checkbox, check it.
Optional - 4) If you have multiple users using this PC and this file, you have to use the button below this option to set it for all users.
This way, you will only need to click the icon and then press Yes in the User Account Control pop-up.
Even if you are an administrator, you still have to confirm the UAC pop-up every time you run something that requires administrative privileges, that's the default Windows 7 setting. If you want to get rid of the pop-up "Yes / No" window of UAC, you would have to disable it completely.
! I do not recommend doing this for regular users !
1) Go to Start -> Control Panels -> Action Center (a blue flag icon)
2) Select "Change User Account Control settings"
3) Move the slider all the way down to "Never notify" and press OK.
Then then UAC pop-up will never show again if you launch anything.
Votes
Translate
Translate
Report
Report
New Here ,
Exe file will be used by client side. It is not possible to do those settings in all client pc.And all other applications running good without problem.Why is Captivate exe file is different than others?i Think problem is with exe file only.Is there any other way?
Votes
Translate
Translate
Report
Report
Guest
Jul 21, 2013 Jul 21, 2013
LATEST
Hi Realpsojed,
I turned off UAC and it definately solved the problem described above, however I am running into another error message that is very specific to open a standard user account.
http://forums.adobe.com/post!input.jspa?container=2168&containerType=14
take a look at my post above and any help would be much appreciated.
Thanks.
Votes
Translate
Translate
Report
Report
