7 Replies Latest reply on Mar 17, 2013 6:46 PM by Cooperstown.Com
    Need Help With REFind
    Cooperstown.Com
      I have a form filed and need to make sure that there is not URL's being passed through it.  I would like to search the field and test it for "http" and/or "www", if those charters are present I would like to send it to a special page that handels it and then abort the rest of the script.
      Can anyone help me with this?
      Thanks!
      Nick
        • 1. Re: Need Help With REFind
          BreakawayPaul Level 2
          See if this helps.  It's from my regex cheat sheet.
          <cfset regex = "^(http://|www)[a-zA-Z0-9\-\.]+\.[a-zA-Z]{2,3}(/\S*)?$" />
          Then :
          #refind(regex,"your_string")#
          Should return 1 if there's a match, or 0 if there isn't.
          • 2. Re: Need Help With REFind
            Cooperstown.Com Level 1
            Paul,
            You were spot on with your post, I can't thank you enough for your help!
            Have the code in place and it is working like a charm.
            Nick
            • 3. Re: Need Help With REFind
              Paul,
              After a bit more testing I noticed that your regex was not working.  I had to use the following code to getthe script to work:
              <cfset stringToSearch = '#form.xxx#'>
              (Notice, I had to use single quotes instead of double quotes, the double quotes were killing me!)
              <p>
              <cfset foundit = '#FindNoCase("http",stringToSearch)#'>
              <cfif foundit gt 0>
                      <cflocation url="http://www.xxx.com">
                      <cfabort>
              </cfif>
              Had to use:
              #refind("http","your_string")#
              Instead of:
              Have no idea about Regular Expressions, wish I understood what your code is doing so that I could work on it to get it to work but all I know is that the script works this way and I will take it!  :-)
              Thanks again for your help!
              Nick
              • 4. Re: Need Help With REFind
                Hi Nick,
                Do you have an example case that it doesn't match?  You asked for one that would find a URL starting with either http:// or www.  If you only need it to find ones starting with http://, then that's a simpler regex.
                • 5. Re: Need Help With REFind
                  Paul,
                  I wanted to use your code but when I uesed #refind(regex,"your_string")# and tested it it did not catch any of the test data that I used.  I used the following code and it worked with all of the test data:
                  <cfif foundit gt 0>
                          <cfabort>
                  </cfif>
                  It should not matter that I used FindNoCase instead of ReFind?
                  If I used the following do you think it should have worked?
                  <cfset foundit = '#FindNoCase(regex,stringToSearch)#'>
                  <cfif foundit gt 0>
                          <cfabort>
                  </cfif>
                  I liked you code because it also tested for www and that would have been good to test for!
                  Thanks for all your help!
                  Nick
                  • 6. Re: Need Help With REFind
                    Tweaked the regex.  It should find a url with or without the http://
                    <cfset regex = "^(https?:\/\/)?([\da-z\.-]+)\.([a-z\.]{2,6})([\/\w \.-]*)*\/?$" />
                    <cfset my_search_string = "http://forums.adobe.com/">
                    <cfset foundit =refind(regex,my_search_string>
                    <cfif foundit gt 0>
                            <cfabort>
                    </cfif>
                    If you are passing a variable as the second argument in refind(), leave the quotes out.  If it's a string, then it needs to be quoted.
                    • 7. Re: Need Help With REFind
                      Paul,
                      I will work on it tomorrow and get back to you.
                      Thanks again!
                      Nick
