3 Replies Latest reply: Mar 16, 2013 5:29 PM by Rick Gerard RSS
    Basic Effects & Presets Question (image)
    perfectblue Community Member
      When you apply effects and presets to a layer within your composition why is there no symbol indicating FX have been applied to the layer.
      In photoshop if you were to apply a drop shadow to a layer it would indicate it with an FX icon on the layer.
      In the image below I have a text layer that I added a "Fade out Slow" effect to. However, I see no indication on the timeline or on the layer itself that an FX was applied.
      (please click image to enlarge)
        • 1. Re: Basic Effects & Presets Question (image)
          Mylenium CommunityMVP
          You need to straighten out your terminology: They are layer styles and indeed there is no indication of them being applied, however it's easy enough to hit UU to reveal all "modified properties" and thus check whether layer styles are used or not. Normal effects can be revealed with the E shortcut.
          Mylenium
          • 2. Re: Basic Effects & Presets Question (image)
            Todd_Kopriva Adobe Employee
            The item that you have a red box around is not an effect; it is an animation preset. That is why you don't see an indicator of an effect being applied on your layer after appying this animation preset.
            Read about the differences and details here.
            • 3. Re: Basic Effects & Presets Question (image)
              Rick Gerard CommunityMVP
              Animation presets can be just a single keyframe or hundreds of them and hundreds of effects all applied to a single layer. YOu can create your own (and this is a real good idea if you use AE a lot) to save setup time and make your workflow more efficient. Just apply all the effects and keyframes you want, press UU to reveal everything that you've done to the clip, select everything in the timeline and then choose Animate>Save Animation Preset.
              Animation presets are more like Actions in Photoshop than the Layer Effects you apply in the Layers palette in Photoshop. Run and action and only the history panel will tell you what you just did.
              The effects in AE are more like the layer effects in Photoshop. Filters in Photoshop only behave like Effects in AE if you convert the layer to a Smart Object. AE is entirely non destructive editing. Your original source footage is never changed. AE builds everything from scratch a pixel at a time using the original source files as a starting place.
              As has been mentioned, pressing the 'U' key twice will reveal everything that has been changed or added to your layer. Pressing the 'e' key will reveal all Effects added. It's much easier for me to figure out what's been done to a layer in AE than it is to figure out what's been done to a Photoshop file. It's also a lot easier keep from fouling up the original.
