1 Reply Latest reply on Mar 17, 2013 10:58 AM by BingoFriday
    Saving Transitions and Effects as favorites in PPro CS 6
    EdwurdAdam Level 1
      I am working with Premiere Pro CS 6
      I have added transition and changed it parameters a little bit. I want to save this as a favorite so I can use it again and again without having to change the parameters every time.
      How can I do this? Can I also do it for filters as well?
      Thanks in advance
        • 1. Re: Saving Transitions and Effects as favorites in PPro CS 6
          BingoFriday Level 2
          You can't manipulate the preset transitions and save that manipulation as far as I know. This is how you do it. - You take a clip and either put a filter on it (lens flare for instance) or manually build the effect you want on it (opacity for a fade in for instance). Then you select/highlight that effect title in the Effects Controls panel - click on the panel menu icon to the upper right of the Effect Controls panel - choose preset - name it - save it.
