5 Replies Latest reply on Mar 18, 2013 12:17 PM by Curt Y
    CS6 Not responding
    Audrey Hinsman
      I have CS6 and LR4.3 installed (for a while).  I am not not able to Edit In LR4.3 4 photos that I wish to make into a panorama.  CS6 will start to the first window and then locks (Not Responding).  I have uninstalled and reinstalled CS6 and delete the preferences, all to no avail.
        • 1. Re: CS6 Not responding
          Noel Carboni Level 8
          Can you please describe in more detail how Photoshop figures in this?  How are you invoking it exactly.  I ask because you mention LR4.
          Are you using the Photoshop Photomerge feature?
          -Noel
          • 2. Re: CS6 Not responding
            Audrey Hinsman Level 1
            The problem is that CS6 will not start.  It starts momentarily and then freezes.  The first time I noticed it was when I tried to merge 4 photos from LR4.3 (Edit in - Merge to Panorama in CS).  CS6 started and then froze.  Then I tried to start CS6 by itself with exactly the same results.
            • 3. Re: CS6 Not responding
              Does anything get logged in your system's Event Log?
              You could try resetting Photoshop's preferences by pressing and holding Control - Shift - Alt (or Command - Shift - Option if a Mac) immediately upon cold-starting Photoshop.  If you're quick enough - and you have to be very quick to get the keys down - it will prompt you to confirm deletion of your current preferences set.
              -Noel
              • 4. Re: CS6 Not responding
                Noel,
                I have tried twice (successfully) to delete the preference.  And the problem continues.  What do I look for in the system's Event Log?  I did review it but saw nothing related to Adobe or CS6.
                • 5. Re: CS6 Not responding
                  Curt Y Level 7
                  If you are not fast enough you might have better luck hold down 2 of the keys, start PS and immediately press and hold the 3rd key.
                  If windows OS look in Help for Event Log instructions.  Look for Faulting Module line.
