4 Replies Latest reply on Mar 19, 2013 11:08 AM by maxhodges0
    another GREP challenge!
    maxhodges0 Level 1
      OK given this source text
      Another two-grapheme kanji. The combination is visual (the @sun@ 日 is seen partly obscured by a @tree@ 木), but the meaning is abstract (^EAST^), so see this as a $rising$ sun and $visualize$ the idea of ^EAST^. Try to associate the image with a memorable sunrise from your own experience. An $on-yomi$ compound appears in the next entry.
      I can set SUN and TREE with this
      "\^(.+?)\^", "$1"
      And I get take get both EAST and EAST with this:
      "\@(.+?)\@", "$1"
      But this one only gets RISING but not VISUALIZE or ON-YOMI:
      "\$(.+?)\$", "$1"
      what am I doing wrong?
        • 1. Re: another GREP challenge!
          maxhodges0 Level 1
          This is odd. Maybe a bug in Indesign? The first two find all the occurances, but the final one stops after it finds the first one. Both in scripting and also with the GUI Find/Change dialog.
          • 2. Re: another GREP challenge!
            maxhodges0 Level 1
            found a workaround. If I just run the grep multiple times it will get them all
                    Private Sub AnnotationStyler(ByRef targetCell As InDesign.Cell, ByRef doc As InDesign.Document, ByRef app As InDesign.Application)
                        Dim mycharstyle As InDesign.CharacterStyle = doc.CharacterStyles.Item("[None]")
                        Dim myparastyle As InDesign.ParagraphStyle = doc.ParagraphStyles.Item("SK-comment")
                        app.ClearOverridesWhenApplyingStyle = True
                        For Each para As InDesign.Paragraph In targetCell.Paragraphs
                            para.AppliedCharacterStyle = mycharstyle
                            para.AppliedParagraphStyle = myparastyle
                        Next
                        ' style text wrapped in ^ as bold
                        FindChangeGREP(app, doc, targetCell, "SK-bold", "\^(.+?)\^", "$1")
                        ' style text wrapped in @ = smallcaps
                        FindChangeGREP(app, doc, targetCell, "SK-smallcaps", "\@(.+?)\@", "$1")
                        ' style text wrapped in $ as italic
                        FindChangeGREP(app, doc, targetCell, "SK-italic", "\$(.+?)\$", "$1")
                        FindChangeGREP(app, doc, targetCell, "pointinghand", "☞")
                    End Sub
                    Private Sub FindChangeGREP(ByRef app As InDesign.Application, ByRef doc As InDesign.Document, ByRef theCell As InDesign.Cell, ByVal CharacterStyle As String, ByVal FindWhat As String, ByVal changeTo As String)
                        Dim mycharstyle As InDesign.CharacterStyle = doc.CharacterStyles(CharacterStyle)
                        app.FindGrepPreferences = idNothingEnum.idNothing
                        app.ChangeGrepPreferences = idNothingEnum.idNothing
                        app.FindChangeGrepOptions.IncludeFootnotes = False
                        app.FindChangeGrepOptions.IncludeHiddenLayers = False
                        app.FindChangeGrepOptions.IncludeLockedLayersForFind = False
                        app.FindChangeGrepOptions.IncludeLockedStoriesForFind = False
                        app.FindChangeGrepOptions.IncludeMasterPages = False
                        app.ChangeGrepPreferences.AppliedCharacterStyle = mycharstyle
                        app.FindGrepPreferences.FindWhat = FindWhat
                        If changeTo <> "%" Then app.ChangeGrepPreferences.changeTo = changeTo
                        theCell.ChangeGrep()
                    End Sub
            • 3. Re: another GREP challenge!
              designmon79 Level 1
              You can also put $ in character class [$]. Then it will gets RISING, VISUALIZE or ON-YOMI:
              Try this.
              "[$](.+?)[$]", "$1"
              Mon
              • 4. Re: another GREP challenge!
                maxhodges0 Level 1
                that works! Thank you! can you explain why it works to me?! (why mine didn't work?)
