32 Replies Latest reply: Mar 21, 2013 10:27 AM by JJMack RSS
    Photoshop and Murphy's Law
    Aegis Kleais Community Member
      Not much of a Q&A here, but I just want to state that it HAS to be STATITICALLY IMPOSSIBLE how often Adobe apps like Photoshop open up modal windows RIGHT over where you need to see something underneath them.  If you move it, invariably it will be over information you need again.
      When drawing selections with the marquee it's always AMAZING how if you want to drag out, say, a 800px wide selection, Photoshop WILL NOT allow this by 1 pixel.  You can get it to 799px, and if you move your mouse EVER SO SOFTLY to the right, it will jump to 801px.
      Just funny that I've fought with these types of things for so long.  I wonder if other people have had to deal with things like.  Have you guys had Murphy's Law moments in Adobe apps?
        • 1. Re: Photoshop and Murphy's Law
          DrStrik9 Community Member
          Try unchecking "Prefs>Interface>"Open Documents as Tabs." Also check Enable Floating Document Window Docking, so you can have it both ways. Obvious solution: get a larger monitor, or two monitors.  :+)
          You can set a precise Marquee selection size using Style>Fixed Size. No more dragging and wondering.
          Bottom line to Murphy's Law in Adobe apps is to know the apps very well. We control them; they do not control us.  :+)
          • 2. Re: Photoshop and Murphy's Law
            Well, there's using the app wrong, and then there's forcing a change to your workflow in order to get the application to work as intended.  I see the former as a fault on me that needs correction and the latter as a fault on the application that hinders the user to forcibly alter themselves to adapt to a limitation.
            I did as you asked and unchecked the OPEN DOCUMENTS AS TABS and checked ENABLE FLOATING DOCUMENT WINDOW DOCKING.  I took the marquee and attempted to manually drag out a size (I'm aware of the FIXED SIZE in the options bar, however I see this as unproductive compared to an on-the-fly solution as it requires me to set it on and turn it off otherwise subsequent marquees are affected)  Anyways, I dragged a marquee and sure enough it went from 799px to 801px.
            As for monitors, I am planning on getting a new PC in January of 2014, and I do think I'll be getting 2 monitors, but are you talking about physically larger monitors or higher-resolution capable ones?  I have a 24" Dell 1920x1080 right now.  What is the logic behind this request?
            I appreciate the feedback!
            • 3. Re: Photoshop and Murphy's Law
              Noel Carboni Community Member
              You should try it with a second monitor.  It really likes having a whole monitor just for editing the image.
              -Noel
              • 4. Re: Photoshop and Murphy's Law
                I'm a little confused.  It's ON a whole monitor right now.
                I mean, I still plan on getting 2 monitors just because it allows me to have more goodness in front of me at a time, but for the time being, what is the difference between PS on my current monitor vs. another?
                • 5. Re: Photoshop and Murphy's Law
                  I think we mean TWO monitors, one for editing the image, and the other to contain all the tools, which can then remain open at all times.
                  • 6. Re: Photoshop and Murphy's Law
                    OH!  I never thought about setting it up that way.
                    So basically you have the app opened in 1 monitor and just move it's floating palettes to the other?  Hmm.  Sounds interesting.  I'm gonna have to remember this when I get my second monitor down the line.
                    • 7. Re: Photoshop and Murphy's Law
                      Jeff Schewe Community Member
                      This is a function of the lack of precision of your mouse, not Photoshop. If your mouse has enough precision, you can indeed do per pixel accurate functions in Photoshop. Photoshop is the reason I use a very precise wired optical mouse by Logitech (the current one is an M500). With it, I can drag out a marquee selection and watch as the size changes pixel by pixel. BTW, with a very precise mouse, I see no difference between the tabed UI or floating windws. On one computer (single display) I use the application frame and on the other with 3 displays, I use floating windows. Even on the 3 display computer, I have no problem moving with per pixel accuracy even though I have the velocity turned way high to be able to move the mouse accross three displays with a swipe.
                      As far as the modal thing, yeah, that's always a problem...but over the years you get used to it and learn to anticipate.
                      • 8. Re: Photoshop and Murphy's Law
                        Yes, two monitors.
                        You'll never want to use a system with just one monitor again.
                        -Noel
                        • 9. Re: Photoshop and Murphy's Law
                          I have a Razer Naga (about 5600DPI)  Not sure I could get more precise than that!   Maybe it's a setting like mouse acceleration that's causing the issue?
                          • 10. Re: Photoshop and Murphy's Law
                            I don't know...check the various mouse options. The only other variable is I'm running OS X 10.6.8/10.8.2, not Windows. However, when I plug in my mouse to my laptop running Win 7 via Parrallels, it behaves the same so I don't think it's a Mac/Win thing and it's certainly not a Photoshp issue.
                            • 11. Re: Photoshop and Murphy's Law
                              conroy Community Member
                              Are you viewing at less than 100% zoom, i.e. zoomed out, when you experience the loss of precision relative to actual image pixels? If so, then that's not surprising.
                              • 12. Re: Photoshop and Murphy's Law
                                Here's my Photoshop layout across two monitors, by the way, just to give you some ideas...
                                -Noel
                                • 13. Re: Photoshop and Murphy's Law
                                  Very cool Noel.  Maximize the work area.  I think I'll try that when the time comes.  Thanks for the great idea.
                                  • 14. Re: Photoshop and Murphy's Law
                                    I did make sure that I was at a 1:1 zoom ratio before draggin the selection, as the interpolation of higher or lower than that could understandably have caused the same issue.
                                    • 15. Re: Photoshop and Murphy's Law
                                      JJMack Community Member
                                      I see Astronomy need a lot of sharpening options. My setup has the pallets on left screen perhaps because I was born lefty then converted by my farther to righty
                                      • 16. Re: Photoshop and Murphy's Law
                                        Interesting, JJ.  Do you push the mouse around with your left hand?
                                        -Noel
                                        • 17. Re: Photoshop and Murphy's Law
                                          No but I sit centered between the screens I saw your set up has three displays. Like with a wacom tablet you stear with what you see on screen the mouse or pen is easy to use offset to the right or left depending on what hand you use your head will still be centered. My tool palette is on the left of the work screen like the binding in a book I work on the right screen pickup up tools and layers from the center of my setup. The layers,channels,paths, and the Actions and the History pallets are all near center. Other less used palettes way left some info and setting palettes will pop out on the right side of my work display.
                                          • 18. Re: Photoshop and Murphy's Law
                                            I don't have three displays at the moment, just two.  One day I'll add a big new one in the middle, but I'm waiting for a specific design to mature (Dell U3013 seems promising).
                                            It's an interesting subject, this picking one side or the other for Photoshop panels...  It may have to do with what side of the brain is the "technical" hemisphere and what side is "artistic".
                                            But in my case I think it was more a matter of the left monitor having started out as being the one and only monitor, then adding the new one on the right (seemed logical; pixel coordinates increase to the right, with the upper-left corner of the left monitor being 0,0).  Then I moved all the panels off of Photoshop, which was originally entirely on the left monitor, onto the right one.  In general, if one wants more space, one just imagines making a window wider on the right side, no?
                                            There is, of course, no technical reason the left monitor has to be primary, and pixel coordinates can of course be negative.
                                            I did think about what I would change around when I add a third monitor in the middle...  Would I want to have Photoshop features and functions on all three of them, or just the big middle one for editing and one of the two on the side for panels.  That way the third one could host reference material, browsers, etc.  I do still have a few panels (like Brush and Brush Presets) that I only occasionally show, and like you I have them showing in my left monitor (main display); perhaps those could find a permanent home on the left monitor.
                                            -Noel
                                            • 19. Re: Photoshop and Murphy's Law
                                              30" 16:10 100dpi 2560x1600 pixels
                                              I would much prefer if they would produce a higher resolution display something like a
                                              20" 16:10 150dpi 2560x1600 pixels.
                                              I found the old IBM t220 22" 16:10 204dpi 3840x2400 pixels resolition was to high for the font size used in most application user interface and current video adapters do not suppotrs it 3840x2400 pixels you need to drive it with more the one adapter as 4 1920x1200 displays with desktop spread across the four logical displays.
                                              • 20. Re: Photoshop and Murphy's Law
                                                Nice part about the 100 ppi 30 inch display is that my current 20 inchers are 100ppi, so turning them up sideways along both sides of the big one would yield "ears" that would match up darned near perfectly.
                                                I think HDMI 1.4 and certainly the newest HDMI standard handle sufficient resolutions for high ppi displays.
                                                -Noel
                                                • 21. Re: Photoshop and Murphy's Law
                                                  Well...I like using 3 displays, two are 30" NEC (center and right with Lightroom) and a 24" left (for Photoshop panels). Depending on what I'm doing, I can have Bridge full screen on the right with Photoshop or InDesign or Illustrator in the center and application panels on the left, smaller display. Or, if I'm working in Word, center and Bridge (right) and Safari (left), it's pretty handy to have each display have a task and purpose. Yeah, it would be "better" to have 3, 30" but I don't have the space :~( The 24" is fine for panels and "other" use...
                                                  See: http://schewephoto.com/test/3-screen.png
                                                  • 22. Re: Photoshop and Murphy's Law
                                                    Jeff, do you feel any neck strain with that much display space?  It's something I've been wondering about.
                                                    -Noel
                                                    • 23. Re: Photoshop and Murphy's Law
                                                      New machine will be set up today have not purchased ram yet I see Dell has 8GB ECC ram for $108 and I see other have 8GB registered dimms for $79 would same me  $116 for 32GB.  Also Wacom has a new 13" 1920x1080  169DPI LED LCD tablet display for $1000 that looking good to me http://www.wacom.com/creative/products/pen-displays/cintiq/cintiq-13hd I'm a little colorblind so 75% aRGB is fine with me.
                                                      • 24. Re: Photoshop and Murphy's Law
                                                        Nope...most of the work is done on the center display...I only look to the right (right 30" either Lightroom or Bridge for image selection) or left (24" Photoshop panels) when I need to. I use command keys where I can remember them...
                                                        I've been using multiple displays since–well maybe 1994-1995 and Photoshop 4-5. I like setting up a multiple display so that I can use muscle memory to use/see what I need to use and work.
                                                        I can easily adapt to a single display workspace like a laptop on the road...there I use PS, Bridge & LR full screen and use the Apple Command/Tab function to move between active apps.
                                                        So, I can work single display or multiple display, but the single display is considerably less efficient. Course, I'm not really trying to do much on the laptop when on the road other that confirm imports (into LR) and selection edits.
                                                        • 25. Re: Photoshop and Murphy's Law
                                                          -Noel
                                                          There is no problem handling the high resolution there are two problems though.  One is font size and the other the huge number of pixels involved when you deal with higher resolution.  A font the characters are 1/4" 1/4" on a 100dpi display. That font on the IBM 200DPI display character size would be 1/16" x 1/16"  on and apple retina 300 DPI display would be 1/36" x 1/36"  and on a Samson galaxy 4 400DPI display would be 1/64" x 1/64" . A 30" 16:10 display with a 400DPI resolution would display  10176x6360 = 64,719,360 Display adapters can not handle 64MP  if they could you can display any camera image using actual pixels on a 30" 400dpi display.
                                                          • 26. Re: Photoshop and Murphy's Law
                                                            Likewise, I've been using multiple displays a long time, but not that big.  Good to hear it's not taxing.  I hadn't thought it would be, and maybe it would even be helpful (on the theory that more exercise is better).  Thanks for confirming.
                                                            -Noel
                                                            • 27. Re: Photoshop and Murphy's Law
                                                              A character which measures 1/4" x 1/4" at 100 ppi would measure:
                                                              1/8" x 1/8" at 200 ppi
                                                              1/12" x 1/12" at 300 ppi
                                                              1/16" x 1/16" at 400 ppi
                                                              • 28. Re: Photoshop and Murphy's Law
        JJ's point is that without complete UI adherence to the scaling settings (not that any application we know of fails at that ), a high ppi display could make things virtually unusable.
        The task of being flexible enough to adapt to the user's display needs AND flexible enough to work on multiple platforms must be pretty difficult.  That said, it's been a LONG TIME since people have been asking Adobe for bigger UI elements.  I wonder whether the Retina display work is flexible enough to expand or contract to other sizes.
        -Noel
        • 29. Re: Photoshop and Murphy's Law
        I know what JJ's point was! I only corrected the calculations.
        • 30. Re: Photoshop and Murphy's Law
        Sorry, I figured you knew, but I was just segwaying back to discussing his point that the world isn't ready for high ppi.  But without high ppi the world won't make itself ready.  But the monitor makers won't make high ppi displays until the world is ready...  Ad nauseum.
        Unfortunately, OS makers now all seem to think we'd all prefer a 9 inch tablet to a big monitor anyway.
        -Noel
        • 31. Re: Photoshop and Murphy's Law
        No problem
        Or http://en.wikipedia.org/wiki/Google_Glass
        • 32. Re: Photoshop and Murphy's Law
        Yes I made a mistake I was thinking more about pixel count and not size  while the objjct size is cut in half when an area pixel density is changed from 100dpi to 200dpi the number of pixels increases four fold. I used the pixel  factors not the size factors.  I used 4,  9 and 16 when the size factors were 2,3 and 4.  Sorry...
