2 Replies Latest reply on Nov 7, 2007 12:38 AM by ljonny18
    Using XML with Flex - Best Practice Question
    ljonny18 Level 1
      Hi
      I am using an XML file as a dataProvider for my Flex application.
      My application is quite large and is being fed a lot of data – therefore the XML file that I am using is also quite large.
      I have read some tutorials and looked thorough some online examples and am just after a little advice. My application is working, but I am not sure if I have gone about setting and using my data provider in the best possible (most efficient) way.
      I am basically after some advice as to weather I am going about using (accessing) my XML and populating my Flex application is the best / most efficient way???
      My application consists of the main application (MXML) file and also additional AS files / components.
      I am setting up my connection to my XML file within my main application file using HTTPService :
      <mx:HTTPService
      id="myResults"
      url=" http://localhost/myFlexDataProvider.xml"
      resultFormat="e4x"
      result="myResultHandler(event)" />
      and handling my results with the following function:
      public function myResultHandler(event:ResultEvent):void
      myDataFeed = event.result as XML;
      within my application I am setting my variable values by firstly delacring them:
      public var fName:String;
      public var lName:String;
      public var postCode:string;
      public var telNum:int;
      And then, giving them a value by “drilling” into the XML, E;g:
      fName = myDataFeed.employeeDetails.contactDetails.firstName;
      lName = myDataFeed.employeeDetails.contactDetails.lastName;
      postCode = myDataFeed.employeeDetails.contactDetails.address.postcode;
      telNum = myDataFeed.employeeDetails.contactDetails.postcode;
      etc…
      Therefore, for any of my external (components in a different AS file) components, I am therefore referencing there values using Application:
      import mx.core.Application;
      And setting the values / variables within the AS components as follows:
      fName = Application.application.myDataFeed.employeeDetails.contactDetails.firstName;
      lName = Application.application.myDataFeed.employeeDetails.contactDetails.lastName;
      As mentioned this method seems to work, however, is it the best way to do it??? :
      - Connect to my XML file
      - Set up my application variables
      - Give my variables values from the XML file ……
      Bearing in mind that in this particular application there are many variable that need to be set and there for a lot of lines of code just setting up and assigning variables values from my XML file.
      Could someone Please advise me on this one????
      Thanks a lot,
      Jon.
