1 Reply Latest reply on Mar 20, 2013 10:06 AM by rush_pawan
    Allow an author to add a dynamic number of datefields to a dialog
    Modulo216 Level 1
      Hi All.  So I've run into a problem that I'm not sure how to even approach.  I'm very familiar with creating dialogs for my authors, but what I need to do is allow them dynamically Add and Remove a number of datefields.  I add a datefield now to my dialog.xml like so:
      <startDate
      jcr:primaryType="cq:Widget"
      fieldLabel="Start Date"
      name="./startDate"
      xtype="datefield"/>
      What I'd like to do is have a Add and Remove button / link that will add or remove a new datefield to the dialog.  From there I also need to figure out how to handle these items on the server side.
      If someone could point me in the right direction that would be very helpful.
        • 1. Re: Allow an author to add a dynamic number of datefields to a dialog
          rush_pawan Level 4
          Instead of using datefield widget directly use multified widget and configure it with datefield as below
                         <dates
                              fieldLabel="Dates"
                              name="./dates"
                              xtype="multifield">
                              <fieldConfig
                                  jcr:primaryType="nt:unstructured"
                                  xtype="datefield"/>
                          </dates>
          So here first create a node with xtype as "multifield" and then inside that node create another nt:unstructured node and configure it using xtype "datefield".
          You can access this field similar to how you access multifield in normal case (as String[]).
          Let me know if you need more information or faced any issue during implementation.
          Pawan
