8 Replies Latest reply on Mar 22, 2013 5:53 AM by codonvirginia
    Replication does not work
    codonvirginia
      I click on "Test connection " button in Default Agent (publish). I got this error. Anyone know why, can you help me.? This is CQ5 5.5.
      19.03.2013 08:47:45 - Create new HttpClient for Default Agent
      19.03.2013 08:47:45 - * Auth User: admin
      19.03.2013 08:47:45 - * HTTP Version: 1.1
      19.03.2013 08:47:45 - adding header: Action:Test
      19.03.2013 08:47:45 - adding header: Path:/content
      19.03.2013 08:47:45 - adding header: Handle:/content
      19.03.2013 08:47:45 - deserialize content for delivery
      19.03.2013 08:47:45 - No message body: Content ReplicationContent.VOID is empty
      19.03.2013 08:47:45 - Sending POST request to http://localhost:4505/bin/receive?sling:authRequestLogin=1
      19.03.2013 08:47:45 - sent. Response: 403 Forbidden
      19.03.2013 08:47:45 - Replication (TEST) of /content not successful. Conversation follows
      19.03.2013 08:47:45 - ------------------------------------------------
      19.03.2013 08:47:45 - Sending message to localhost:4505
      19.03.2013 08:47:45 - >> POST /bin/receive HTTP/1.0
      19.03.2013 08:47:45 - >> Action: Test
      19.03.2013 08:47:45 - >> Path: /content
      19.03.2013 08:47:45 - >> Handle: /content
      19.03.2013 08:47:45 - >> Content-Length: 0
      19.03.2013 08:47:45 - >> Content-Type: application/octet-stream
      19.03.2013 08:47:45 - << HTTP/1.1 403 Forbidden
      19.03.2013 08:47:45 - << Connection: Close
      19.03.2013 08:47:45 - << Server: Day-Servlet-Engine/4.1.32
      19.03.2013 08:47:45 - << Content-Type: text/html
      19.03.2013 08:47:45 - << Date: Tue, 19 Mar 2013 12:47:45 GMT
      19.03.2013 08:47:45 - << Transfer-Encoding: chunked
      19.03.2013 08:47:45 - << <html><head><title>
      19.03.2013 08:47:45 - << 403
      19.03.2013 08:47:45 - << Forbidden
      19.03.2013 08:47:45 - << </title></head><body><h1>
      19.03.2013 08:47:45 - << </h1>
      19.03.2013 08:47:45 - << </body></html>
      19.03.2013 08:47:45 - Message sent.
      Replication test failed
      Forbidden
      Jenny
        • 1. Re: Replication does not work
          orotas Level 4
          I'd guess you have the wrong password configured in your authoring instance. If you changed the default admin password on your publish instance you need to make sure you also set up that password in you replication agent in author.
          If your passwords are correct I'd check the logs on your publish instance to see if there are any errors in error.log when you send the test. I am assuming this can't be a network problem since you are pointing at localhost as the server name so you much have both the author instance and the publish instance on the same box.
          • 2. Re: Replication does not work
            codonvirginia Level 1
            Hi orotas,
            I have checked the password. The password is ok. This is the error when I click on " Test connection".
            Replication test to http://localhost:4505/bin/receive?sling:authRequestLogin=1
            19.03.2013 12:39:57 - Create new HttpClient for Default Agent
            19.03.2013 12:39:57 - * Auth User: admin
            19.03.2013 12:39:57 - * HTTP Version: 1.1
            19.03.2013 12:39:57 - adding header: Action:Test
            19.03.2013 12:39:57 - adding header: Path:/content
            19.03.2013 12:39:57 - adding header: Handle:/content
            19.03.2013 12:39:57 - deserialize content for delivery
            19.03.2013 12:39:57 - No message body: Content ReplicationContent.VOID is empty
            19.03.2013 12:39:57 - Sending POST request to http://localhost:4505/bin/receive?sling:authRequestLogin=1
            19.03.2013 12:39:57 - sent. Response: 403 Forbidden
            19.03.2013 12:39:57 - Replication (TEST) of /content not successful. Conversation follows
            19.03.2013 12:39:57 - ------------------------------------------------
            19.03.2013 12:39:57 - Sending message to localhost:4505
            19.03.2013 12:39:57 - >> POST /bin/receive HTTP/1.0
            19.03.2013 12:39:57 - >> Action: Test
            19.03.2013 12:39:57 - >> Path: /content
            19.03.2013 12:39:57 - >> Handle: /content
            19.03.2013 12:39:57 - >> Content-Length: 0
            19.03.2013 12:39:57 - >> Content-Type: application/octet-stream
            19.03.2013 12:39:57 - << HTTP/1.1 403 Forbidden
            19.03.2013 12:39:57 - << Connection: Close
            19.03.2013 12:39:57 - << Server: Day-Servlet-Engine/4.1.32
            19.03.2013 12:39:57 - << Content-Type: text/html
            19.03.2013 12:39:57 - << Date: Tue, 19 Mar 2013 16:39:57 GMT
            19.03.2013 12:39:57 - << Transfer-Encoding: chunked
            19.03.2013 12:39:57 - << <html><head><title>
            19.03.2013 12:39:57 - << 403
            19.03.2013 12:39:57 - << Forbidden
            19.03.2013 12:39:57 - << </title></head><body><h1>
            19.03.2013 12:39:57 - << </h1>
            19.03.2013 12:39:57 - << </body></html>
            19.03.2013 12:39:57 - Message sent.
            Forbidden
            • 3. Re: Replication does not work
              Jitu Tomar
              Hi ,
              I think Author agent credentials are not matched with publish instance credentials. please verify again.
              To verify try to Login on publish instance. let's see if agent configuration credentials work in publish instance as well.
              Jitu tomar
              IntelliGrape India
              • 4. Re: Replication does not work
                do you know why I got this message " Cannot serve request to /content/census/en/test.html on this serve" in Publish sever.
                I create the page in the author then active the page . In the pubish sever , I open that page then I got the message "  Cannot serve request to /content/census/en/test.html on this serve" .
                Anyone can help me.. I try to work on Replication. What step do I need to do.. I follow some document on internet but not help much..
                Thank you very much.
                Jenny
                • 5. Re: Replication does not work
                  Sham HC Level 7
                  Hi Jenny
                  You get the message "Cannot serve request ..." because the page test.html is not available in the publish instance. That means replication is failed. You need to fix replication issue first.
                  For replication return a 403 Forbidden in response to a request from a author indicate that the server refuses to allow the requested action. In other words, the server can be reached, but the server declined to allow the requested access. As other recommended
                  *    Might be a wrong user/id & password configured in replication agent.
                  *    You might have some firewall settings etc not passing authorization header.
                  *    There is some permission issue at publish instance.
                  This is simple use case & should work, You can file a daycare ticket to get official help.
                  Sham
                  • 6. Re: Replication does not work
                    HI,
                    How do I know publish instance has enough permission?
                    • 7. Re: Replication does not work
                      Sham HC Level 7
                      Hi Jenny,
                        Is the agent id configured in replication agent at your author instance is admin OR different user?
                      Sham
                      • 8. Re: Replication does not work
                        Hi Sham,
                        It is admin, The connect is working now.
                        Jenny
