4 Replies Latest reply on Mar 20, 2013 11:42 AM by CarlosCanto
    VBscript to edit all drawings in a folder
    RedFlannelShirt Level 1
      I have some +900 legacy pdf's that need to have a title and date change.
      The pdf's where generated in ArcMAP 10 so the text appears as individual letters.
      So I wrote a script that creates a knockout and adds the required text.
      I can get this to work for an individual file but I can't figure out is how to have the script perform it for all the pdf's in a folder.
      Very new to scripting form the illustrator end so any help would be appreciated, Kevin
      Set appRef = CreateObject("Illustrator.Application")
      Set docRef = appRef.Open("C:\Work\City_Wide_Zoning\0_Spring_2013\Test\A001.pdf")
      'Knockout
      'Create a new rectangle with measured in points (top, left side, width, height)
      'Ref                                          y, x,  w,  h
      Set newRectangle = docRef.PathItems.Rectangle(66,55,118,20)
      'Text
      'Ref                                      y, x,     w,   h
      Set rectRef = docRef.PathItems.Rectangle(62, 54.5, 100, 15)
      Set areaTextRef = docRef.TextFrames.AreaText(rectRef)
      areaTextRef.Contents = "New Date" & vbCrLf & "New Name"
      areaTextRef.Selected = True
      ' Colour Settings for Knockout
      Set colorRef = CreateObject("Illustrator.RGBColor")
      colorRef.Red = 255
      colorRef.Green = 255
      colorRef.Blue = 255
      newRectangle.FillColor=colorRef
      newRectangle.StrokeColor=colorRef
      appRef.Redraw
      areatextRef.TextRange.CharacterAttributes.textFont = appRef.textfonts.getByName("Arial-BoldMT")
      areaTextRef.TextRange.CharacterAttributes.Size = 5.25
      appRef.Redraw
      docRef.Close 1 'aiSaveChanges
      Set docRef = Nothing
        • 1. Re: VBscript to edit all drawings in a folder
          Muppet Mark Level 5
          If you are NEW to scripting then what apps etc. do you need to script…? and how new are you…? A change of language gets you much more help in the Adobe forums…
          • 2. Re: VBscript to edit all drawings in a folder
            CarlosCanto Adobe Community Professional & MVP
            Mark is correct, if you're new to scripting you'll be better off learning Javascript
            in the mean time, here's a sample of how to use the files in a folder, try it with a folder with a few files, just to test
            Set fso = CreateObject("Scripting.FileSystemObject")
            'set pdfFolder = fso.getFolder("C:\Work\City_Wide_Zoning\0_Spring_2013\Test")
            set pdfFolder = fso.getFolder("c:\temp")
            Set pdfFiles = pdfFolder.Files
            For Each pdfFile In pdfFiles
                      MsgBox pdfFile.Name
                      'insert your script here
            Next
            set pdfFile = Nothing
            set pdfFiles = Nothing
            set pdfFoler = Nothing
            set fso = Nothing
            • 3. Re: VBscript to edit all drawings in a folder
              Thank you Carlos for pointing me in the right direction since I am still new to scripting. I will take Mark's advice and try tto make the move to Javascript.
              Anyway here is the solution that works for me in a Win XP environment
              Thanks again gentlemen, Kevin
              Dim fso
              set pdfFolder = fso.getFolder("C:\Work\City_Wide_Zoning\0_Spring_2013\1to5")
              '          MsgBox pdfFile.Name
              Set docRef = appRef.Open(pdfFolder & "\" & pdfFile.Name)
              ' My script here
              Next
              set pdfFolder = Nothing
              set fso = Nothing
              • 4. Re: VBscript to edit all drawings in a folder
                you're welcome, you may want to move the application ref out of the loop, it does not need to be created for each file
                Next
