3 Replies Latest reply on Mar 19, 2013 11:21 AM by Elwood123Bermuda
    CFGRID issue
    Elwood123Bermuda
      I have a simple grid with Cold Fusion 9.0.2
      <cfquery datasource="db" name="q1">
                Select 'a', 0
                union
                Select 'b', 0
                union
                Select 'c', 0
                union
                Select 'd', 0
                union
                Select 'e', 0
                union
                Select 'f', 0
        </cfquery>
      <cfform name="formgrid" action="customersku_submit.cfm">
          <cfgrid name = "gridname" format="html"
              selectmode="edit"
              font="Tahoma" fontsize="12"
              query = "q1">
          </cfgrid>
          <cfinput type = "submit" name = "submit" value = "Submit">
      </cfform>
      If I click the number value for a and enter 1 and then click to the number value on field f and press submit it returns the value I changed not as the a but as the f.
      structFIELDNAMESSUBMIT,__CFGRID__FORMGRID__GRIDNAMEGRIDNAME.COMPUTED_COLUMN_1
      array
      1f
      GRIDNAME.COMPUTED_COLUMN_2
      array
      11
      GRIDNAME.ORIGINAL.COMPUTED_COLUMN_1
      array
      1f
      GRIDNAME.ORIGINAL.COMPUTED_COLUMN_2
      array
      10
      GRIDNAME.ROWSTATUS.ACTION
      array
      1U
      SUBMITSubmit__CFGRID__FORMGRID__GRIDNAME__CFGRID__EDIT__=2 COMPUTED_COLUMN_1 Y COMPUTED_COLUMN_2 Y 1 U f f 1 0
