6 Replies Latest reply on Mar 19, 2013 3:49 PM by Muppet Mark
    HOW? = export to same folder without errors
    scott memberg
      Hey Guys,
      Ok here is my issue. I have to do several things to a document in indesign when I am finished. I have to save it as a PDF, make JPGs of the page/s and save it and close it. I have been spending HOURS trying to figure out this scripting thing. Here is what i have so far:
      tell application "Adobe InDesign CS5.5"
                set properties of PDF export preferences to properties of PDF export preset "[High Quality Print]"
                set theFilepath to file path of active document
                tell active document
        export format PDF type to theFilepath without showing options
                end tell
      --JPEG Preference Settings
                set myJPEG_Prefs to JPEG export preferences
                tell myJPEG_Prefs
                          set resolution to 48
                          set JPEG Quality to maximum
                          set JPEG export range to export range
                          set JPEG Rendering style to baseline encoding
                end tell
      --save file
                if modified of active document is true then
                          tell active document to save
                end if
      close active document
      end tell
      Problem is that I get an error when i run it:
      Result:
      error "Adobe InDesign CS5.5 got an error: Cannot save to the file “Desktop”, because it is already open." number 9491
      In the "events window":
      get file path of active document
        --> file "Web Design 1:Users:scottmemberg:Desktop:"
      export active document format PDF type to file "Web Design 1:Users:scottmemberg:Desktop:" without showing options
        --> error "Cannot save to the file “Desktop”, because it is already open." number 9491
      Where did I go wrong? Do i need an "if" statement some where? Please Help!
        • 1. Re: HOW? = export to same folder without errors
          Muppet Mark Level 5
          The line…
          Is not correct… This returns the files parent ie ( the desktop folder ) you can't export to this… try something like…
          set theFilepath to file path of active document & "myFile.pdf"
          of cause I did no check this file already exist so it would be overwritten… if it did…
          • 2. Re: HOW? = export to same folder without errors
            Jump_Over Level 5
            theFilepath is the last folder from your file path but supposed to be a file.
            so use it like this:
                      set myDestination to file path of active document as string
                      set myDocname to get name of active document
                      if myDocname contains "indd" then set myDocname to (characters 1 thru -6 of myDocname)
                   export format PDF type to myDestination & myDocname & ".pdf" without showing options
              end tell
            In case of .jpg is the same story
            Jarek
            (oh, sorry Mark, didn't see yours, coffee, cigarettes and time is running )
            Message was edited by: Jump_Over
            • 3. Re: HOW? = export to same folder without errors
              scott memberg Level 1
              I have re-worked some of the script:
                        tell myJPEG_Prefs
                        end tell
                        end tell
                export format JPEG to myDestination & myDocname & ".jpeg" without showing options
                        end tell
              end tell
              BUT, it has a problem with the jpeg part.... im so close.
              • 4. Re: HOW? = export to same folder without errors
                Muppet Mark Level 5
                It's the same problem as before… You need to export a file to the full file path of a file not a folder… Choose folder will return a folder… add name & file extension to this and you will have a valid full path in which to save…
                'Web Design 1:Users:scottmemberg:Desktop:' -- this is just partial path
                'Web Design 1:Users:scottmemberg:Desktop:foo.pdf' -- this would be a full path ( it no end in : a folder in HFS path )
                • 5. Re: HOW? = export to same folder without errors
                  Thanks guys for your help! Here is what I arrived at and it works perfectly for me.
                            set properties of PDF export preferences to properties of PDF export preset "crops-bleeds"
                            tell myJPEG_Prefs
                                      set JPEG export range to export all
                            end tell
                            end tell
                    export format JPG to myDestination & myDocname & ".jpg" without showing options
                            end tell
                            end if
                            if modified of active document is false then
                            end if
                  end tell
                  And now with 1 button i can save my finger in clicking time...rofl
                  • 6. Re: HOW? = export to same folder without errors
                    Muppet Mark Level 5
                    Untested but you don't need to step in & out of tall blocks like that…
                    tell application "Adobe InDesign CS5"
                              tell myJPEG_Prefs
                              end tell
                                        set myDestination to file path as string
                                        if modified is true then save
                              end tell
                    end tell
