5 Replies Latest reply on Mar 20, 2013 10:37 AM by Peter Grainge
    RH10 Fatal Error: cannot run macro: RegisterResolvers in compilation script
    cmarksp
      Recently upgraded from RH8 to 10. Since then I've not been able to compile webhelp not even once. I get the same error in the same place every time. It always happens at 'generating content' and the error is:
      Adobe RoboHelp 10 has stopped working.
      Output View:
      Initializing compiler
      Generating WebHelp 5.50 (10.0.0.287)
      Template Active Script Error: fail to initialize script
      Template Error: can not resolve macro: RegisterResolvers
      After perusing the forums, I've deleted the .lng file and tried to recompile; changed the project setting language; added a line in the .lng file ( <element name="FtsMaxResult" value="Search results per page" />); created a new project and tried to compile; tried a different output path.
      None of these solutions worked. What else can I do?
      I know nothing of macros/templates and am the only person who has ever worked on RH and on this project that I cannot get to compile. RH is installed and run from my local drive.  I never had this problem on RH8.
