1. Re: A 'Best Practices' Question on Components
DanWilson_ Mar 20, 2013 8:57 AM (in response to Aegis Kleais)1MB of memory is not a very large amount of data to cache things in.
However, one would make the argument of whether you needed to cache them
at all. If you have a low traffic site, and your components don't take a
long time to set up, I might avoid the caching of the components because
it isn't needed.
If you do need to cache the components, you'll need a way to kick over
the cache when you make updates. This is often done by a URL parameter
and using the Application.onRequestStart() method to see if the
components need reinitialization.
If you are going down this route, I'd say it might be a good idea to
start looking at a factory object to handle the creation of the
components and to manage the state for you. You can look at LightWire or
DI/1 for something simple, or Wirebox or Coldspring for something more
robust. It'll help you later on when your design may require one
component to make another one of your components.
DW
2. Re: A 'Best Practices' Question on Components
Adam Cameron. Mar 20, 2013 9:52 AM (in response to Aegis Kleais)I'd not optimise your code until you need to. And the size of components you are talking about are not big anyhow.
So I'd design your application the way it is logically supposed to come together, and deal with optimisations when you identify a need (and a resolution) for them.
So if you have a component that should be a singleton: implement it that way; if you have a component that should be transient: implement it that way.
Adam
3. Re: A 'Best Practices' Question on Components
Aegis Kleais Mar 20, 2013 9:53 AM (in response to DanWilson_)Thanks for your input Dan!
I haven't done the metrics, and I might just be picking nits when it comes to the performance difference between doing it one way vs. the other.
I know that when I do instantiate the applications into the APPLCIATION scope, making subsequent changes (without restarting the application) is ganked simply because the server is holding onto the old code for the duration of the app's lifespan. Generally, my remote environment, which is controlled by my host, is restrictive only to the point where they forcibly cache template requests, so if I update page code and upload it to them via FTP, often times I have to login into the CP and use their "clear template cache" function. A pain in the butt, but it seems that's how they "optimize" their shared hosting Coldfusion plans.
I guess I can just store everything into the app, and maybe even reduce the application timespan from 4 hours to something smaller like 2 hours. The application startup can take a moment longer to server up the first request, but at least I wouldn't have to code tons of logic on "Is this component instantiated?" and instead, just write code as if it DOES exist (but of course, using TRY blocks to capture in the event it isn't)
4. Re: A 'Best Practices' Question on Components
Aegis Kleais Mar 20, 2013 10:10 AM (in response to Adam Cameron.)Hey Adam, thanks for the input!
So you're saying "Just code in a way where the application assumes all components are instantiated" (and use try/catch blocks in the event the component is not. Right? I have to look up what "singleton" and "transient" components are. If that's literal
5. Re: A 'Best Practices' Question on Components
Aegis Kleais Mar 20, 2013 10:48 AM (in response to Adam Cameron.)Ah, found a good readup on Singleton and Transients. >> http://www.fancybread.com/blog/post.cfm/a-coldfusion-transient-factory-example
Interesting read.
6. Re: A 'Best Practices' Question on Components
Adam Cameron. Mar 20, 2013 6:29 PM (in response to Aegis Kleais)So you're saying "Just code in a way where the application assumes all components are instantiated" (and use try/catch blocks in the event the component is not. Right? I have to look up what "singleton" and "transient" components are. If that's literal
I more meant that just instantiate the thing when you need it, eg:
theObjectYouNeed = new TheComponent();
theResult = theObjectYouNeed.someMethod();
etc.
It doesn't sound like you have enough components to worry about doing this, but you might want to look at ColdSpring (or something of its ilk) to manage the components/objects for you. It does make life easier if you need to scale up, although it will perhaps had a slight overhead to start with, it won't be such that it matters.
Adam
7. Re: A 'Best Practices' Question on Components
Aegis Kleais Mar 22, 2013 10:43 AM (in response to Adam Cameron.)So would it be fine then for, in the onApplicationStart() to just loop through all components in the 'coms' folder and store them into a structure, say, 'APPLICATION.coms'. So if I had, say 3 coms called 'data.cfc', 'templates.cfc' and 'error.cfc', then there would be a:
APPLICATION.coms.data
APPLICATION.coms.error
APPLICATION.coms.template
And in th event that I needed to create an instance off one (like template, since it handles per-user template generation needs rather than data which handles calls made to datasources), I could do something like:
REQUEST.myTemplateObj = new APPLICATION.coms.template().
And, being in the REQUEST scope, it will die automatically at the end of the request, right?
8. Re: A 'Best Practices' Question on Components
Adam Cameron. Mar 24, 2013 1:59 PM (in response to Aegis Kleais)No. You need to understand the difference between a component and an object.
When you go
application.coms.template = new Template();
That's creating an object (application.coms.template) instance of the component (Template). So on the RHS of that statement, you need to use a component name.
If in your code you need a tansient Template object, just create one. only put non transients into the application scope.
Adam
9. Re: A 'Best Practices' Question on Components
Aegis Kleais Mar 24, 2013 2:27 PM (in response to Adam Cameron.)So I should instead reference it like
<cfset REQUEST.template = APPLICATION.coms.template.init() />
The init() method would return THIS, and then the REQUEST.template can operate independent of the template component that I instantiated into the APPLICATION scope. Is that the right line of thinking?
10. Re: A 'Best Practices' Question on Components
Adam Cameron. Mar 24, 2013 3:05 PM (in response to Aegis Kleais)No, just go request.template = new Template().
You need a Template instance each request, so just instantiate it each request. There's no point in having it in the application scope too.
Adam
11. Re: A 'Best Practices' Question on Components
Aegis Kleais Mar 24, 2013 3:51 PM (in response to Adam Cameron.)Got it.
