10 Replies Latest reply on Jun 24, 2013 11:01 AM by elainecc
    Assistance needed with hovers
    slitherax
      Hi there,
      In my project, I have several squares. When the mouse is hovered over these squares, I want them to change colour and when the mouse is taken away, I want them to change back. I managed to achieve this by creating copies of the squares with a different colour, and then showing and hiding appropriately with simple show and hide code, but this caused some problems. Therefore, I am wondering if this can be done via code, perhaps with the :hover CSS selector, or some other means. If so, I would be deeply gratified to know how this could be done.
      Many thanks,
      Dee Roberts
        • 1. Re: Assistance needed with hovers
          TimJaramillo Level 4
          Hi there, you can do this through code using the jQuery "mouseenter" and "mouseleave" events:
          // code on Stage.document.compositionReady:
          // hide "over" state initially ("over" is a shape nested inside the "btn" symbol)
          sym.getSymbol("btn").$("over").hide();
          sym.$("btn").mouseenter(function(){
               sym.getSymbol("btn").$("over").fadeIn(1000);
          sym.$("btn").mouseleave(function(){
               sym.getSymbol("btn").$("over").fadeOut(500);
          • 2. Re: Assistance needed with hovers
            slitherax Level 1
            Thank you for your reply, but this doesn't really do what I want. I want the colour of the square to change when the mouse enters it, but I don't want to have to use any other elements. Is this possible, or am I barking up the wrong tree, so to speak?
            • 3. Re: Assistance needed with hovers
              Hi there, hopefully this will help you out, note that the object who's color we're changing btn.RectangleShape in my example below) has to be a simple shape div in Edge, it can't be a symbol.
              Example:
              www.timjaramillo.com/code/edge/rollover3_gsap_colorChange
              Source:
              www.timjaramillo.com/code/edge/_source/rollover3_gsap_colorChange.zip
              // load GSAP anim library
              yepnope(
              nope:[
                        'greensock/TweenMax.min.js',
                        'greensock/easing/EasePack.min.js',
                        'greensock/plugins/CSSPlugin.min.js',
                        'greensock/plugins/ColorPropsPlugin.min.js'
              complete: init
              //when yepnope has loaded everything execute init();
              function init (){
                        var coloredSquare = sym.getSymbol("btn").$("RectangleShape");
                                        TweenMax.to(coloredSquare, 1, {backgroundColor:"#938461", ease:Power2.easeIn});
                             TweenMax.to(coloredSquare, 1, {backgroundColor:"#000000", ease:Power2.easeIn});
              • 4. Re: Assistance needed with hovers
                Dam4222 Level 1
                It seems like all you want to do is this:
                http://dl.dropbox.com/u/9159616/squares.zip
                You could do this using code the way Tim suggested. But doing this without code is actually really easy for me. Just create a square> convert it to a symbol> animate the color> add mouseenter with Sym.play and mouseleave with Sym.PlayReverse > duplicate the symbol (not copy and paste). Then go into each symbol and modify the color.
                Hope that helps.
                Adam
                • 5. Re: Assistance needed with hovers
                  Rafael Zuma Level 1
                  Well, apparently not able to do the way down yet?
                  sym.$("divObject").animate({backgroundColor:"#ff6600},1000);
                  Below does not work in texts!
                  sym.$("textObject").animate({color:"#ff6600},1000);
                  • 6. Re: Assistance needed with hovers
                    elainecc Adobe Employee
                    Rafael-
                    You're missing a quotation mark in there around "color".  Also, backgroundColor is the wrong parameter.  Remember that by using the animate() API, you're referring to CSS values.  So it would be background-color and color.
                    Hopet hat helps.
                    -Elaine
                    • 7. Re: Assistance needed with hovers
                      Rafael Zuma Level 1
                      But it is not working both ways.
                      I used keys, because I will put more CSS selectors in animate ().
                      • 8. Re: Assistance needed with hovers
                        Hi, Rafael-
                        I'm pointing out a syntax error - you're missing a quotation mark (").
                        -Elaine
                        • 9. Re: Assistance needed with hovers
                          Rafael Zuma Level 1
                          After hexadecial, right? I know... i wrote quickly, sorry!
                          For example... in the code below, the animation run correctly TOP and LEFT, but COLOR not run.
                          "sinopse" is a text.
                          Symbol.bindElementAction(compId, symbolName, "${_sinopse}", "mouseover", function(sym, e) {
                               sym.$("sinopse").animate({top:-5, left:100, color:"#ff6600"},1000,'linear');
                          • 10. Re: Assistance needed with hovers
                            Hey, Rafael-
                            So the problem is more a limitation with jQuery.
                            http://api.jquery.com/animate/
                            According to the documentation, you'd need to use jQuery.Color or jQueryUI.
                            -Elaine
