3 Replies Latest reply on Mar 22, 2013 5:14 PM by wfmc staffer
    Premiere Pro denoiser hiss issues
    emiling85
      I used the denoiser on all of clips. It sounds perfect on my timeline. But when I export it, there is a 3 second hiss at the beginning of the clip that I cannot get rid of. I've tried using Audition and even Final Cut products, and nothing gets rid of it. What gives?
        • 1. Re: Premiere Pro denoiser hiss issues
          Jim_Simon Level 9
          Audition is the right tool.  If it can be done, it's best done there.
          • 2. Re: Premiere Pro denoiser hiss issues
            the_wine_snob Level 9
            Welcome to the forum.
            Here is a current, somewhat similar thread: http://forums.adobe.com/message/5171440?tstart=0#5171440
            • 3. Re: Premiere Pro denoiser hiss issues
              wfmc staffer Level 2
              If the noisy clips are the only thing on that audio track, you can add the Denoiser effect from the audio mixer panel rather that applying it to each clip. The effect will apply to everything on that audio track, and I've found that it gets rid of the delays and oscillations of the Denoiser effect lots of times.
              Open the audio mixer panel and you should see a slider there for each track and a master. At the top left of the mixer panel UI is a triangle toggle like the ones on all of the bins in Premiere's UI. Use the toggle to expand the mixer panel to show the fx bus. There you can pull down a list of all of the audio fx to apply to each track. After adding an effect to a track, right click on it and choose "edit" to make adjustments. You can do this while your timeline is playing to hear the results. You can also keyframe effects on the timeline by setting the track display to "show track keyframes". That option is down on the audio tracks in the timeline panel.
              Since I learned of these options, I know find them indispensable and you them on nearly every project
