9 Replies Latest reply on Mar 21, 2013 9:02 AM by Trevorׅ
    Actual Image size
    kerosk_inddNew
      Firstly, thanks to Jongware to provide this helpful script.
      I have found the script in this from created by Jongware (see link below). Its working fine.
      http://forums.adobe.com/message/4329277#4329277
      But I require little changes in it.
      This script saves a report containing the image name and size.
      Can I get the actual image size in pica by this script.
      For Example:
      Actual image size is 29p0.75 x 11p11.356
      Currently script writes the size i.e. 29.1 x 11.9 pt.
      Need to modified this so that it gives acutal size in pica i.e., 29p0.75 x 11p11.36.
      Kerosk
        • 1. Re: Actual Image size
          Trevorׅ Adobe Community Professional
          see if it helps to change the line
          default: w = w.toFixed(1); h = h.toFixed(1);
          to
          default: w = w.toFixed(3); h = h.toFixed(3);
          • 2. Re: Actual Image size
            Sorry I missread your post, ignore the above answer
            • 3. Re: Actual Image size
              I think this is what you are look for
              (not tested)
              // Changed from Jonware's script
              //  FOR PICAS ONLY !!!!!!!!!!!!!!!
              var hmu = app.activeDocument.viewPreferences.horizontalMeasurementUnits,
                      vmu =  app.activeDocument.viewPreferences.verticalMeasurementUnits;
              app.activeDocument.viewPreferences.horizontalMeasurementUnits = app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.PICAS;
              res = [];
              imgs = app.activeDocument.allGraphics;
              unitname = "pc";
              for (i=0; i<imgs.length; i++)
                h = imgs[i].parent.geometricBounds[2] - imgs[i].parent.geometricBounds[0];
                w = imgs[i].parent.geometricBounds[3] - imgs[i].parent.geometricBounds[1];
                // some fair rounding
                res.push (imgs[i].itemLink.name+'\t'+w+' x '+h+' '+unitname);
              defaultFile = new File (Folder.myDocuments+"/"+app.activeDocument.name.replace(/\.indd$/i, '')+".txt");
              if (File.fs == "Windows")
                writeFile = defaultFile.saveDlg( 'Save report', "Plain text file:*.txt;All files:*.*" );
              else
                writeFile = defaultFile.saveDlg( 'Save report');
              if (writeFile != null)
                if (writeFile.open("w"))
                  writeFile.encoding = "utf8";
                  writeFile.write (res.join("\r")+"\r");
                  writeFile.close();
              app.activeDocument.viewPreferences.horizontalMeasurementUnits = hmu;
              app.activeDocument.viewPreferences.verticalMeasurementUnits = vmu;
              • 4. Re: Actual Image size
                kerosk_inddNew Level 1
                Thanks, Trevor for your reply.
                I ran this script but it gives the image size 29.0625 x 11.9463335673014 pc.
                Whereas I needed the actual image size that is 29p0.75 x 11p11.356.
                Help!
                Kerosk
                • 5. Re: Actual Image size
                  Be warned that what you call "actual image size" is still rounded to *some* degree. As you can see in the value returned by Trevor's script, InDesign is accurate up to 13 or 14 digits, and I doubt you would want to see all of them.
                  Anyway, the problem occurs because picas are not a decimal unit -- they are actually 'duodecimal' (base 12). Using points as the base of measurement, dividing the result by 12, and then showing *only* three significant digits leads to the same display as in InDesign:
                  //DESCRIPTION:Write image size report
                  // A Jongware Script 21-mar-2013
                  app.activeDocument.viewPreferences.horizontalMeasurementUnits = app.activeDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.POINTS;
                  res = [];
                  unitname = getCurrentUnit();
                    // some required rounding
                    h = ptToPc (h);
                    w = ptToPc (w);
                  else
                      writeFile.close();
                  function ptToPc (value)
                    value = Math.round(1000*value);
                    var result = Math.floor(value/12000);
                    var remain = value - 12000*result;
                    if (remain == 0) return String(result)+'p';
                    return String(result)+'p'+String(Math.round(remain)/1000);
                  • 6. Re: Actual Image size
                    Thanks a lot, Jongware.
                    This is what I needed. Really appreciate for your time and support.
                    Kerosk
                    • 7. Re: Actual Image size
                      Hi Jongware,
                      you need to change the
                      to
                      unitname = "pc";
                      as the function doesn't exist any more in the script.
                      Reminds me of a comment I posted not so long ago
                      • 8. Re: Actual Image size
                        That's my own fault ... I use a large "scratch" file for snippets and little scripts such as this. By now it contains almost 700 individual snippets -- 28,000 lines --, and I can usually find a good base to start a new snippet from.
                        In this case, it also contained the *original* version of this script! The entire 'get current unit' stuff is obsolete by now, as it works solely with pica's, but I didn't notice the 'missing' function because JS found it anyway ... 4,100 lines lower!
                        • 9. Re: Actual Image size
                          Jongware,
                          Any chance of posting that one ?
                          P.s.
                          I had some trouble earlier getting onto the forum,
                          I tried to (and thought I had) post on the original thread http://forums.adobe.com/message/4329277#4329277 a small typo correction on that script.
                          You wrote
                          case MeasurementUnits.PICAS: return "pt";
                          which should have been
                          return "pc";
                          That's what I meant when I wrote
                          "Reminds me of a comment I posted not so long ago "
                          Regards
                          Trevor
